Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement
Views: 16K
View statistics:
Past 24 Hours:
8
Past 7 Days:
32
Past 30 Days:
187
All Time:
15,592
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Is your LCD screen acting strange? Replacing the CCD Sensor Module is a straight forward task that will increase the clarity of your screen.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Battery: step 1, image 1 of 2 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Battery: step 1, image 2 of 2
      • Locate the battery door at the bottom of the camera.
      • Press down on the door and slide it back. The door will pop open.
      Ask FixBot
    2. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: step 2, image 1 of 1
      • Remove the battery from the door that you opened in the previous step.
      Ask FixBot
    1. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: step 3, image 1 of 3 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: step 3, image 2 of 3 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: step 3, image 3 of 3
      • There are two screws on the left and right sides of the camera, and two screws on the bottom.
      • Use a PH00 screwdriver and remove the six 2.9mm screws.
      Ask FixBot
    2. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: step 4, image 2 of 2
      • Use hands to gently pry the front casing away from the camera.
      Ask FixBot
    1. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, CCD Sensor Module: step 5, image 1 of 2 Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement, CCD Sensor Module: step 5, image 2 of 2
      • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
      • The second picture shows what these tabs look like in their open positions.
      Ask FixBot
    2. Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement: step 6, image 1 of 1
      • Grasp the CCD Sensor Module and remove it.
      Ask FixBot
5 other people completed this guide.
iDeleted
2,101 Reputation
39 Guides authored
1 Guide Comment
where I can buy it?
Francesco Cortese - Reply Share
Past 24 Hours: 8
Past 7 Days: 32
Past 30 Days: 187
All Time: 15,592
