Sony Cyber-shot DSC-P100 Camera Lens Replacement
  1. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: step 1, image 1 of 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: step 1, image 2 of 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: step 1, image 3 of 3
    • First locate the appropriate screws for detachment.
    Ask FixBot
  2. Sony Cyber-shot DSC-P100 Camera Lens Replacement: step 2, image 1 of 1
    • Remove the five screws shown using a Phillips #00 Screwdriver.
    • It is important to put the small screws in a safe location in order to reassemble the casing.
    Ask FixBot
  3. Sony Cyber-shot DSC-P100 Camera Lens Replacement: step 3, image 1 of 1
    • Using a spudger, carefully pry open the front casing.
    Ask FixBot
  4. Sony Cyber-shot DSC-P100 Camera Lens Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-P100 Camera Lens Replacement: step 4, image 2 of 2
    • Carefully separate the front casing from the camera body.
    • CAUTION: Be careful not to break the wire connecting the front casing and the camera.
    Ask FixBot
  5. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: step 5, image 1 of 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: step 5, image 2 of 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: step 5, image 3 of 3
    • Remove the four screws from the casing.
    Ask FixBot
  6. Sony Cyber-shot DSC-P100 Camera Lens Replacement: step 6, image 1 of 2 Sony Cyber-shot DSC-P100 Camera Lens Replacement: step 6, image 2 of 2
    • Carefully pull the back casing away from the camera.
    Ask FixBot
  7. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Camera Lens: step 7, image 1 of 2 Sony Cyber-shot DSC-P100 Camera Lens Replacement, Camera Lens: step 7, image 2 of 2
    • Remove the two screws on the back side of the camera surrounding the LCD screen.
    Ask FixBot
  8. Sony Cyber-shot DSC-P100 Camera Lens Replacement: step 8, image 1 of 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement: step 8, image 2 of 3 Sony Cyber-shot DSC-P100 Camera Lens Replacement: step 8, image 3 of 3
    • Remove the two ribbon traces found on the left side of the lens on the front of camera holding the lens in place.
    • Carefully pull the lens away front the camera until it is released.
    Ask FixBot
  9. Sony Cyber-shot DSC-P100 Camera Lens Replacement: step 9, image 1 of 1
    • The lens is now successfully removed from the camera.
    Ask FixBot
Katie McCraw
191 Reputation
7 Guides authored
Clemson, Team 1-5, Benson Spring 2012 Member of Clemson, Team 1-5, Benson Spring 2012
CLEM-BENSON-S12S1G5
4 Members
15 Guides authored
1 Guide Comment
Is there a way to disassemble the lens to correct the alignment. My daughter dropped it and I think the mechanism has been misaligned.
Macjune Tolentino - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 36
All Time: 3,271
