Sony Cyber-shot DSC-HX1 Button Assembly Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
103
All Time:
1,508
Comments: 5
5 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Removal and replacement of these buttons requires some previous disassembly and removal of the motherboard.
Tools
    1. Sony Cyber-shot DSC-HX1 Button Assembly Replacement, Battery: step 1, image 1 of 1
      • Make sure the surface you place the screen on is clean of debris and dust. Otherwise you risk scratching your screen.
      • Place the camera with the bottom facing you and the lens facing up.
      Ask FixBot
    2. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: step 2, image 1 of 1
      • Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
      Ask FixBot
    3. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: step 3, image 1 of 2 Sony Cyber-shot DSC-HX1 Button Assembly Replacement: step 3, image 2 of 2
      • Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
      • The battery is not shown here. However, normally the battery would be in the displayed compartment.
      Ask FixBot
    1. Sony Cyber-shot DSC-HX1 Button Assembly Replacement, Button Assembly: step 4, image 1 of 1
      • On the top of the inside the battery compartment, remove the #00 6.0 mm Phillips screw.
      Ask FixBot
    2. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: step 5, image 1 of 2 Sony Cyber-shot DSC-HX1 Button Assembly Replacement: step 5, image 2 of 2
      • Lift the button housing from its position on top of the camera.
      Ask FixBot
2 other people completed this guide.
Brianna Greenlaw
1,316 Reputation
5 Guides authored
Cal Poly, Team 17-3, Forte Spring 2015 Member of Cal Poly, Team 17-3, Forte Spring 2015
CPSU-FORTE-S15S17G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 103
All Time: 1,508
