Sony Cyber-shot DSC-H300 Flash Replacement
  1. Sony Cyber-shot DSC-H300 Flash Replacement, Removing screws: step 1, image 1 of 2 Sony Cyber-shot DSC-H300 Flash Replacement, Removing screws: step 1, image 2 of 2
    • Remove the four 6mm Phillips #00 screws.
    Ask FixBot
  2. Sony Cyber-shot DSC-H300 Flash Replacement, Removing screws: step 2, image 1 of 2 Sony Cyber-shot DSC-H300 Flash Replacement, Removing screws: step 2, image 2 of 2
    • Remove the two 6mm Phillips #00 screws.
    • Remove the two 3mm Phillips #00 screws.
    Ask FixBot
  3. Sony Cyber-shot DSC-H300 Flash Replacement: step 3, image 1 of 3 Sony Cyber-shot DSC-H300 Flash Replacement: step 3, image 2 of 3 Sony Cyber-shot DSC-H300 Flash Replacement: step 3, image 3 of 3
    • Use the flat end of a plastic spudger to pry apart the rear cover from the body of the camera.
    • Be careful not to damage the three plastic clips securing the top edge of the rear cover.
    Ask FixBot
  4. Sony Cyber-shot DSC-H300 Flash Replacement, Flash: step 4, image 1 of 3 Sony Cyber-shot DSC-H300 Flash Replacement, Flash: step 4, image 2 of 3 Sony Cyber-shot DSC-H300 Flash Replacement, Flash: step 4, image 3 of 3
    • Remove the six 6mm Phillips #00 screws from the upper case of the camera.
    • Remove the upper case.
    Ask FixBot
  5. Sony Cyber-shot DSC-H300 Flash Replacement: step 5, image 1 of 2 Sony Cyber-shot DSC-H300 Flash Replacement: step 5, image 2 of 2
    • Remove the four 6mm Phillips #000 screws from the bottom of the case.
    Ask FixBot
  6. Sony Cyber-shot DSC-H300 Flash Replacement: step 6, image 1 of 2 Sony Cyber-shot DSC-H300 Flash Replacement: step 6, image 2 of 2
    • Slide the flash out and away from the camera to remove.
    Ask FixBot
Nassr Al Mandhari
121 Reputation
1 Guide authored
USF Tampa, Team S1-G6, Nance Spring 2018 Member of USF Tampa, Team S1-G6, Nance Spring 2018
USFT-NANCE-S18S1G6
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 32
All Time: 2,648
