Sony Cyber-shot DSC-H20 Screen Replacement
  1. Sony Cyber-shot DSC-H20 Screen Replacement, Screen: step 1, image 1 of 2 Sony Cyber-shot DSC-H20 Screen Replacement, Screen: step 1, image 2 of 2
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
    Ask FixBot
  2. Sony Cyber-shot DSC-H20 Screen Replacement: step 2, image 1 of 1
    • Remove all three screws from the bottom of the camera.
    Ask FixBot
  3. Sony Cyber-shot DSC-H20 Screen Replacement: step 3, image 1 of 2 Sony Cyber-shot DSC-H20 Screen Replacement: step 3, image 2 of 2
    • Remove the screws on the left and right sides of the camera.
    Ask FixBot
  4. Sony Cyber-shot DSC-H20 Screen Replacement: step 4, image 1 of 3 Sony Cyber-shot DSC-H20 Screen Replacement: step 4, image 2 of 3 Sony Cyber-shot DSC-H20 Screen Replacement: step 4, image 3 of 3
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
    Ask FixBot
  5. Sony Cyber-shot DSC-H20 Screen Replacement: step 5, image 1 of 1
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
    Ask FixBot
  6. Sony Cyber-shot DSC-H20 Screen Replacement: step 6, image 1 of 3 Sony Cyber-shot DSC-H20 Screen Replacement: step 6, image 2 of 3 Sony Cyber-shot DSC-H20 Screen Replacement: step 6, image 3 of 3
    • Pry the front cover of the camera off with the plastic opening tool.
    Ask FixBot
  7. Sony Cyber-shot DSC-H20 Screen Replacement: step 7, image 1 of 1
    • Remove the power shutter unit.
    Ask FixBot
  8. Sony Cyber-shot DSC-H20 Screen Replacement: step 8, image 1 of 2 Sony Cyber-shot DSC-H20 Screen Replacement: step 8, image 2 of 2
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
    Ask FixBot
  9. Sony Cyber-shot DSC-H20 Screen Replacement: step 9, image 1 of 1
    • Remove the two screws from the bottom of the motherboard.
    Ask FixBot
  10. Sony Cyber-shot DSC-H20 Screen Replacement: step 10, image 1 of 1
    • Use the plastic opening tool to assist you in separating the metal frame from the back cover of the camera.
    Ask FixBot
  11. Sony Cyber-shot DSC-H20 Screen Replacement: step 11, image 1 of 2 Sony Cyber-shot DSC-H20 Screen Replacement: step 11, image 2 of 2
    • Flip the metal frame over to the left side of the camera and onto the surface on which you are working.
    Ask FixBot
  12. Sony Cyber-shot DSC-H20 Screen Replacement: step 12, image 1 of 2 Sony Cyber-shot DSC-H20 Screen Replacement: step 12, image 2 of 2
    • Now remove the LCD screen by bringing the back cover over to the left so that the LCD screen falls into your hand.
    Ask FixBot
3 other people completed this guide.
Rachel Payne
425 Reputation
2 Guides authored
USF Tampa, Team 1-1, Leahy Winter 2015 Member of USF Tampa, Team 1-1, Leahy Winter 2015
USFT-LEAHY-W15S1G1
3 Members
10 Guides authored
1 Guide Comment
Thank you so much. I could successfully open the camera and got the LCD display out. But I couldn't find out how to replace the LCD, I wanted to mean where to open the LCD cable?
ummejamil - Reply Share
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 66
All Time: 2,931
