Sony Cyber-shot DSC-H20 Flash Assembly Replacement
    1. Sony Cyber-shot DSC-H20 Flash Assembly Replacement, Flash Assembly: step 1, image 1 of 2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement, Flash Assembly: step 1, image 2 of 2
      • Slide open the battery cover and remove the battery and the Memory Stick Duo.
      • Return the battery cover to its closed position.
      Ask FixBot
    2. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: step 2, image 1 of 1
      • Remove all three screws from the bottom of the camera.
      Ask FixBot
    3. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: step 3, image 1 of 2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: step 3, image 2 of 2
      • Remove the screws on the left and right sides of the camera.
      Ask FixBot
    4. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: step 4, image 1 of 3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: step 4, image 2 of 3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: step 4, image 3 of 3
      • Press down on the flash cover to raise the flash.
      • Remove both screws that hold the flash cover to the body of the camera.
      Ask FixBot
    5. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: step 5, image 1 of 2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: step 5, image 2 of 2
      • Place the camera upside down with the battery port positioned upward.
      • Slide open the battery port.
      Ask FixBot
    6. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: step 6, image 1 of 3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: step 6, image 2 of 3 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: step 6, image 3 of 3
      • Pry the front cover of the camera off with the plastic opening tool.
      Ask FixBot
    7. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: step 7, image 1 of 1
      • Remove the power shutter unit
      Ask FixBot
    8. Sony Cyber-shot DSC-H20 Flash Assembly Replacement: step 8, image 1 of 2 Sony Cyber-shot DSC-H20 Flash Assembly Replacement: step 8, image 2 of 2
      • Unscrew the screw located at the back left corner of the flash component.
      • Set the flash component aside.
      Ask FixBot
Reuben Martinez
336 Reputation
2 Guides authored
USF Tampa, Team 1-1, Leahy Winter 2015 Member of USF Tampa, Team 1-1, Leahy Winter 2015
USFT-LEAHY-W15S1G1
3 Members
10 Guides authored
1 Guide Comment
how to bye power sutter unit
aloke mondal - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 37
All Time: 1,944
