Sony Cyber-Shot DSC-W170 Top Panel Replacement
  1. Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD Panel Assembly: step 1, image 1 of 3 Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD Panel Assembly: step 1, image 2 of 3 Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD Panel Assembly: step 1, image 3 of 3
    • Be sure to remove the battery before performing this task.
    • Remove the five 4 mm screws with a Phillips #000 screwdriver.
    Ask FixBot
  2. Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 2, image 1 of 1
    • Use an opening pick to pry the LCD panel open.
    Ask FixBot
  3. Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 3, image 1 of 1
    • Gently remove the LCD panel from the rest of the camera.
    Ask FixBot
  4. Sony Cyber-Shot DSC-W170 Top Panel Replacement, Front Panel: step 4, image 1 of 3 Sony Cyber-Shot DSC-W170 Top Panel Replacement, Front Panel: step 4, image 2 of 3 Sony Cyber-Shot DSC-W170 Top Panel Replacement, Front Panel: step 4, image 3 of 3
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
    Ask FixBot
  5. Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 5, image 1 of 1
    • Gently open the front panel and remove it from the rest of the camera.
    Ask FixBot
  6. Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD: step 6, image 1 of 2 Sony Cyber-Shot DSC-W170 Top Panel Replacement, LCD: step 6, image 2 of 2
    • Remove the first side panel to the left of the LCD.
    • Remove the 4 mm screw from the other side panel to the right of the LCD with a Phillips #000 screwdriver.
    Ask FixBot
  7. Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 7, image 1 of 3 Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 7, image 2 of 3 Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 7, image 3 of 3
    • Gently, lift the LCD and carefully open the camera to disconnect the LCD ribbon cable from the motherboard.
    Ask FixBot
  8. Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 8, image 1 of 2 Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 8, image 2 of 2
    • Gently push the connector through the hole to separate the LCD from the metal casing.
    Ask FixBot
  9. Sony Cyber-Shot DSC-W170 Top Panel Replacement, Top Panel: step 9, image 1 of 2 Sony Cyber-Shot DSC-W170 Top Panel Replacement, Top Panel: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Lift up the black bar on the top flat ribbon cable with tweezers.
    • Gently pull the flat ribbon cable until it disconnects from the lens assembly.
    • Be gentle when dealing with the flat ribbon cable.
    Ask FixBot
  10. Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 10, image 1 of 3 Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 10, image 2 of 3 Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 10, image 3 of 3
    • Remove the six 4 mm screws from the lens assembly with a Phillips #000 screwdriver.
    Ask FixBot
  11. Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 11, image 1 of 1
    • Lift the two flat ribbon cables with tweezers.
    Ask FixBot
  12. Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 12, image 1 of 1
    • Peel back the flash assembly on the back of the lens.
    • Remove the two 4 mm screws with a Phillips #000 screwdriver.
    Ask FixBot
  13. Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 13, image 1 of 1
    • Pull out the battery from the side and remove the white tape from the battery assembly with tweezers.
    Ask FixBot
  14. Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 14, image 1 of 2 Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 14, image 2 of 2
    • Disconnect the flat ribbon cable that connects the motherboard to the lens assembly with tweezers.
    Ask FixBot
  15. Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 15, image 1 of 1
    • Push out the lens assembly very gently.
    Ask FixBot
  16. Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 16, image 1 of 1
    • Remove the 4 mm screw from the bottom side of the top panel with a Phillips #000 screwdriver.
    Ask FixBot
  17. Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 17, image 1 of 1
    • Remove the silver 4 mm screw with a Phillips #000 screwdriver from the silver bracket connected to the motherboard.
    Ask FixBot
  18. Sony Cyber-Shot DSC-W170 Top Panel Replacement: step 18, image 1 of 1
    • Pull the top panel off gently.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 22
All Time: 439
