Sony Cyber-Shot DSC-TX9 Lens Replacement
  1. Sony Cyber-Shot DSC-TX9 Lens Replacement, Prerequisites Only: step 1, image 1 of 3 Sony Cyber-Shot DSC-TX9 Lens Replacement, Prerequisites Only: step 1, image 2 of 3 Sony Cyber-Shot DSC-TX9 Lens Replacement, Prerequisites Only: step 1, image 3 of 3
    • Use a Phillips #0 screwdriver to unscrew the six 2mm screws on the outer case of the camera.
    • If there is a battery or SD card inside remove before beginning the process.
    Ask FixBot
  2. Sony Cyber-Shot DSC-TX9 Lens Replacement: step 2, image 1 of 2 Sony Cyber-Shot DSC-TX9 Lens Replacement: step 2, image 2 of 2
    • Use your hands or a Spudger to Pull off the front cover of the camera.
    • If the casing is not coming apart easily, do not force it.
    Ask FixBot
  3. Sony Cyber-Shot DSC-TX9 Lens Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the protective black cover layer with your hands and set it aside.
    • The use of tweezers may be necessary if the cover is difficult to remove.
    Ask FixBot
  4. Sony Cyber-Shot DSC-TX9 Lens Replacement: step 4, image 1 of 2 Sony Cyber-Shot DSC-TX9 Lens Replacement: step 4, image 2 of 2
    • The ZIF connector can be removed by flipping the small black holder into the upright position and then sliding the ribbon cable out carefully.
    • Once this has been done, use tweezers to unplug the flat topped connector for the lens’ circuit board from the motherboard.
    • DO NOT force the ribbon cables or they will rip.
    • Refer to the (Recognizing & Disconnecting Cable Connectors) page for assistance.
    Ask FixBot
  5. Sony Cyber-Shot DSC-TX9 Lens Replacement, Lens: step 5, image 1 of 1
    Buy
    • Using the tweezers carefully remove the broken/damaged lens with its attached circuit board
    Ask FixBot
robert.oliver6
110 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 760
