Introduction
This repair will solve any problems related to flash malfunctions. For example if the flash is not responding or the flash is not as bright as it should be, this repair will fix these issues.
Use a Phillips #0 screwdriver to unscrew the six 2mm screws on the outer case of the camera.
Remove the two screws for the metal plate on the bottom.
Detach the no fuse ribbon cables by sliding them out.
Detach the ZIF connector cables by flipping the small black holder in an upright position and then sliding the cable out carefully.
