Sony Cyber-Shot DSC-TX9 Card Reader Replacement
    1. Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Prerequisites Only: step 1, image 1 of 3 Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Prerequisites Only: step 1, image 2 of 3 Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Prerequisites Only: step 1, image 3 of 3
      • Use a Phillips #0 screwdriver to unscrew the six 2mm screws on the outer case of the camera.
      • If there is a battery or SD card inside remove before beginning the process.
      Ask FixBot
    2. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: step 2, image 1 of 2 Sony Cyber-Shot DSC-TX9 Card Reader Replacement: step 2, image 2 of 2
      • Use your hands or a Spudger to Pull off the front cover of the camera.
      • If the casing is not coming apart easily, do not force it.
      Ask FixBot
    3. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the protective black cover layer with your hands and set it aside.
      • The use of tweezers may be necessary if the cover is difficult to remove.
      Ask FixBot
    4. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: step 4, image 1 of 2 Sony Cyber-Shot DSC-TX9 Card Reader Replacement: step 4, image 2 of 2
      • The ZIF connector can be removed by flipping the small black holder into the upright position and then sliding the ribbon cable out carefully.
      • Once this has been done, use tweezers to unplug the flat topped connector for the lens’ circuit board from the motherboard.
      • DO NOT force the ribbon cables or they will rip.
      • Refer to the (Recognizing & Disconnecting Cable Connectors) page for assistance.
      Ask FixBot
    1. Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Card Reader: step 5, image 1 of 3 Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Card Reader: step 5, image 2 of 3 Sony Cyber-Shot DSC-TX9 Card Reader Replacement, Card Reader: step 5, image 3 of 3
      • Using a Phillips head screw driver, remove the two screws for the metal plate on the bottom.
      • Detach the smaller ribbon cables by sliding them out.
      • Detach the large ribbon cable by flipping the small black holder in an upright position and then sliding the cable out carefully.
      • Detach the ribbon cables slowly and carefully or they will rip.
      Ask FixBot
    2. Sony Cyber-Shot DSC-TX9 Card Reader Replacement: step 6, image 1 of 2 Sony Cyber-Shot DSC-TX9 Card Reader Replacement: step 6, image 2 of 2
      • Carefully remove the Memory card circuit board.
      • The circuit board should come out with little force. If it does not, make sure all connections are disconnected.
      Ask FixBot
Yegor Shea
319 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 35
All Time: 772
