Sony Cyber-Shot DSC-S90 Back Case Replacement
  1. Sony Cyber-Shot DSC-S90 Back Case Replacement, Batteries: step 1, image 1 of 2 Sony Cyber-Shot DSC-S90 Back Case Replacement, Batteries: step 1, image 2 of 2
    • Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
    • While holding the button downwards, slide the door upwards to unlock and open the door.
    Ask FixBot
  2. Sony Cyber-Shot DSC-S90 Back Case Replacement: step 2, image 1 of 1
    • Pull open the door and allow the batteries to fall out.
    Ask FixBot
  3. Sony Cyber-Shot DSC-S90 Back Case Replacement, Back Case: step 3, image 1 of 2 Sony Cyber-Shot DSC-S90 Back Case Replacement, Back Case: step 3, image 2 of 2
    • Remove the 2mm Phillips #00 screw under the battery port door.
    • Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
    Ask FixBot
  4. Sony Cyber-Shot DSC-S90 Back Case Replacement: step 4, image 1 of 2 Sony Cyber-Shot DSC-S90 Back Case Replacement: step 4, image 2 of 2
    • Remove the two 2mm Phillips #00 screws (one on each side of the camera).
    Ask FixBot
  5. Sony Cyber-Shot DSC-S90 Back Case Replacement: step 5, image 1 of 2 Sony Cyber-Shot DSC-S90 Back Case Replacement: step 5, image 2 of 2
    • Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the right side and bottom of the camera with the LCD screen facing you.
    Ask FixBot
  6. Sony Cyber-Shot DSC-S90 Back Case Replacement: step 6, image 1 of 1
    • Pull apart the back case from the main body of the camera.
    Ask FixBot
Alecsander da Silva
320 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 36
All Time: 518
