Sony Clie PEG-UX50 Rear Case Replacement
    1. Sony Clie PEG-UX50 Rear Case Replacement, Rear Cover Case: step 1, image 1 of 3 Sony Clie PEG-UX50 Rear Case Replacement, Rear Cover Case: step 1, image 2 of 3 Sony Clie PEG-UX50 Rear Case Replacement, Rear Cover Case: step 1, image 3 of 3
      • Use the Phillips #1 screwdriver to remove the four screws from the back of the rear cover.
      • Use the Phillips #1 screwdriver to remove the screw on the right side of the rear cover.
      • Use the Phillips #1 screwdriver to remove the screw on the top of the rear cover.
      Ask FixBot
    2. Sony Clie PEG-UX50 Rear Case Replacement: step 2, image 1 of 2 Sony Clie PEG-UX50 Rear Case Replacement: step 2, image 2 of 2
      • Gently pry the rear cover case off to remove both the USB port cover and the hold switch.
      Ask FixBot
    3. Sony Clie PEG-UX50 Rear Case Replacement: step 3, image 1 of 2 Sony Clie PEG-UX50 Rear Case Replacement: step 3, image 2 of 2
      • Remove the side cover.
      • Slowly pull on the rear cover case to separate it from the rest of the device. The case should not come off completely.
      • To avoid wire breakage, do not pull hard on the speaker connection wire.
      Ask FixBot
    4. Sony Clie PEG-UX50 Rear Case Replacement: step 4, image 1 of 1
      • Gently remove the speaker wire from the device.
      • The rear cover case should now be completely separate from the device.
      Ask FixBot
2 other people completed this guide.
Christopher M Garcia
41 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 48
All Time: 4,928
