Up to 20% off select tools
Sony Clie PEG-NR70 Audio Module Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
34
Past 30 Days:
100
All Time:
1,302
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
If the audio in your device is not working, you may need to replace the audio module. This easy step-by-step guide will walk you through the necessary steps to do so.
    1. Sony Clie PEG-NR70 Audio Module Replacement, The Case: step 1, image 1 of 1
      • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
      • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
      Ask FixBot
    2. Sony Clie PEG-NR70 Audio Module Replacement: step 2, image 1 of 1
      • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
      Ask FixBot
    3. Sony Clie PEG-NR70 Audio Module Replacement: step 3, image 1 of 2 Sony Clie PEG-NR70 Audio Module Replacement: step 3, image 2 of 2
      • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
      • Remove the back panel by lifting it away with your hands.
      Ask FixBot
    1. Sony Clie PEG-NR70 Audio Module Replacement, Audio Module: step 4, image 1 of 1
      • Unscrew the 2.5mm screw on the top portion of the audio module with a Phillips #00 screwdriver.
      Ask FixBot
    2. Sony Clie PEG-NR70 Audio Module Replacement: step 5, image 1 of 1
      • Remove the tape that is holding the module down.
      Ask FixBot
    3. Sony Clie PEG-NR70 Audio Module Replacement: step 6, image 1 of 1
      • Lift up the orange ribbon cable and unscrew the two 2.5mm screws located at the corners of the audio module with a Phillips #00 screwdriver.
      Ask FixBot
    4. Sony Clie PEG-NR70 Audio Module Replacement: step 7, image 1 of 1
      • Unplug the audio module from the motherboard by disconnecting the wires by lifting the orange wire up.
      Ask FixBot
Author
with
Daniel Soski
63 Reputation
6 Guides authored
Cal Poly, Team 14-11, Maness Spring 2013 Member of Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 34
Past 30 Days: 100
All Time: 1,302
