Up to 20% off select tools
Sony CPF-IP001 Remote Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
98
All Time:
983
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Parts
Introduction
Go to step 1 ↓
Use this guide if your remote stops functioning. Be sure to have a replacement battery available. The type of battery you will need is a 3 Volt CR2032.
    1. Sony CPF-IP001 Remote Battery Replacement, Remote Battery: step 1, image 1 of 2 Sony CPF-IP001 Remote Battery Replacement, Remote Battery: step 1, image 2 of 2
      • Open battery tray by pushing right on the boxed tab and pulling the battery tray out.
      Ask FixBot
    2. Sony CPF-IP001 Remote Battery Replacement: step 2, image 1 of 2 Sony CPF-IP001 Remote Battery Replacement: step 2, image 2 of 2
      • Replace battery.
      • When placing your new battery in the tray, make sure the positive side on the battery and the positive side on the tray are both facing up.
      Ask FixBot
Author
with
Marlena Perez
442 Reputation
3 Guides authored
Cal Poly, Team 6-14, Maness Spring 2015 Member of Cal Poly, Team 6-14, Maness Spring 2015
CPSU-MANESS-S15S6G14
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 98
All Time: 983
