Sony CPF-IP001 Main Speakers Replacement
  1. Sony CPF-IP001 Main Speakers Replacement, Main Speaker Housing Disassembly: step 1, image 1 of 1
    • Remove two 6mm Phillips #0 screws.
    • Remove two 7.5 mm Phillips #0 screws.
    • Remove seven 4 mm Phillips #0 screws.
    Ask FixBot
  2. Sony CPF-IP001 Main Speakers Replacement: step 2, image 1 of 3 Sony CPF-IP001 Main Speakers Replacement: step 2, image 2 of 3 Sony CPF-IP001 Main Speakers Replacement: step 2, image 3 of 3
    • Remove six 4 mm Phillips #0 screws from the metal backing.
    • Remove six 5 mm Phillips #0 screws from the metal backing.
    • Using the plastic opening tool, remove the metal plate from the main speaker by gently pulling on it.
    Ask FixBot
  3. Sony CPF-IP001 Main Speakers Replacement: step 3, image 1 of 2 Sony CPF-IP001 Main Speakers Replacement: step 3, image 2 of 2
    • Remove the plastic dock cover by using two fingers to push the attached metal piece forward and slide it out of the holes.
    Ask FixBot
  4. Sony CPF-IP001 Main Speakers Replacement: step 4, image 1 of 3 Sony CPF-IP001 Main Speakers Replacement: step 4, image 2 of 3 Sony CPF-IP001 Main Speakers Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Using the plastic opening tool, detach the wires connected to the metal plate
    • When disconnecting the wires, be careful not to pull on the wires themselves. Use the plastic opening tool and the connector to disconnect it.
    • Use the plastic opening tool to remove wires connected to the circuit board on the far right.
    • Use the tweezers to remove wires connected to the circuit board in between the two black wires.
    • Use the tweezers to press the release tab on the front and back of the plastic white wire head.
    • Once the tab is pressed on both sides, lift up to slide wire head out of socket.
    Ask FixBot
  5. Sony CPF-IP001 Main Speakers Replacement: step 5, image 1 of 1
    • Remove two 5 mm Phillips #0 screws.
    Ask FixBot
  6. Sony CPF-IP001 Main Speakers Replacement: step 6, image 1 of 3 Sony CPF-IP001 Main Speakers Replacement: step 6, image 2 of 3 Sony CPF-IP001 Main Speakers Replacement: step 6, image 3 of 3
    • Using the metal spudger, loosen the metal cap at the end of the speaker.
    • Slide down the loosened cap to remove it from the end of the speaker.
    • Simultaneously push down on the buttons and slide the speaker out from the casing.
    Ask FixBot
  7. Sony CPF-IP001 Main Speakers Replacement, Main Speakers: step 7, image 1 of 2 Sony CPF-IP001 Main Speakers Replacement, Main Speakers: step 7, image 2 of 2
    • Remove eight 5 mm Phillips #0 screws.
    Ask FixBot
  8. Sony CPF-IP001 Main Speakers Replacement: step 8, image 1 of 2 Sony CPF-IP001 Main Speakers Replacement: step 8, image 2 of 2
    • Gently pry the speaker out from the housing using the metal spudger.
    • Use wire cutters to cut the red and black wires, or desolder the speaker wires to remove the speaker. See iFixit's guide on How To Solder and Desolder Connections.
    Ask FixBot
4 other people completed this guide.
Marlena Perez
442 Reputation
3 Guides authored
Cal Poly, Team 6-14, Maness Spring 2015 Member of Cal Poly, Team 6-14, Maness Spring 2015
CPSU-MANESS-S15S6G14
4 Members
8 Guides authored
1 Guide Comment
Hi! Does anybody happen to know the model of the speakers? (Or a compatible replacement). I want to give this guide a try and replace my speakers. Thanks!
alecambo - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 27
All Time: 866
