Sony CFD-S70 Disassembly
    1. Sony CFD-S70 Disassembly, Remove the bottom screws: step 1, image 1 of 3 Sony CFD-S70 Disassembly, Remove the bottom screws: step 1, image 2 of 3 Sony CFD-S70 Disassembly, Remove the bottom screws: step 1, image 3 of 3
      • Using a PH2 screwdriver, remove the 5 screws in the holes
      • Don’t forget to remove the two screws circled in green
      • The hole screws can be difficult to remove. Don’t forget to use a magnetized screwdriver
      • The antenna screws can be ignored for now. It’s not important for the disassembly
      Ask FixBot
    2. Sony CFD-S70 Disassembly, Remove the top screws: step 2, image 1 of 3 Sony CFD-S70 Disassembly, Remove the top screws: step 2, image 2 of 3 Sony CFD-S70 Disassembly, Remove the top screws: step 2, image 3 of 3
      • Open the CD cover and remove the two screws using a PH0 screwdriver
      • Move the handle up to unscrew the hole screws using a PH2 screwdriver
      • Be careful around the optical pickup (the small lense)
      Ask FixBot
    3. Sony CFD-S70 Disassembly, Opening the device: step 3, image 1 of 2 Sony CFD-S70 Disassembly, Opening the device: step 3, image 2 of 2
      • Turn the device on his back and pull back and up the bottom portion of the device
      • There’s a connector attached, be careful
      Ask FixBot
    4. Sony CFD-S70 Disassembly, Removing a cable: step 4, image 1 of 1
      • Be careful, the connector is fragile
      Ask FixBot
    5. Sony CFD-S70 Disassembly, Removing and unplugging the main: step 5, image 1 of 3 Sony CFD-S70 Disassembly, Removing and unplugging the main: step 5, image 2 of 3 Sony CFD-S70 Disassembly, Removing and unplugging the main: step 5, image 3 of 3
      • Remove the two screws with a PH2
      • Remove the connector on the left side of the mainboard
      • Stress the right side where there’s the audio connections and pull the main by the left
      Ask FixBot
    6. Sony CFD-S70 Disassembly, Disconnecting connectors: step 6, image 1 of 2 Sony CFD-S70 Disassembly, Disconnecting connectors: step 6, image 2 of 2
      • On the bottom of the main, gently disconnect the connector
      • This connector is VERY fragile. Use something to hold it in place
      • Like the connector, remove the Flex cable from the main
      • Also use caution while removing it. It can break/cut very easily
      Ask FixBot
    7. Sony CFD-S70 Disassembly, Disconnecting connectors: step 7, image 1 of 3 Sony CFD-S70 Disassembly, Disconnecting connectors: step 7, image 2 of 3 Sony CFD-S70 Disassembly, Disconnecting connectors: step 7, image 3 of 3
      • Carefully flip the main and disconnect like the others the cables. You can now remove the mainboard
      • Like before, they’re very fragile
      Ask FixBot
    8. Sony CFD-S70 Disassembly, Removing the front: step 8, image 1 of 2 Sony CFD-S70 Disassembly, Removing the front: step 8, image 2 of 2
      • Now it’s time to remove the front of the device. There’s two little brackets on each side that is retaining the front
      Ask FixBot
    9. Sony CFD-S70 Disassembly, Pulling the front tabs: step 9, image 1 of 2 Sony CFD-S70 Disassembly, Pulling the front tabs: step 9, image 2 of 2
      • Using a flat screwdriver or any other flat and thin tool, pry the outside tabs working your way down and pull the front from the top of the device
      • There’s two little tabs with screw holes. Be careful not to damage them
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Have fun :D
Maxence Chartre
200 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 36
Past 30 Days: 133
All Time: 2,070
