Up to 20% off select tools
Sony CDX-GT540UI Fuse Replacement
Views: 11K
View statistics:
Past 24 Hours:
5
Past 7 Days:
29
Past 30 Days:
129
All Time:
11,119
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will show how to replace a bad fuse, which will cause the device not to turn on.
Before any repair work can be done, one must remove the device from the vehicle. To do so follow this link to see a vehicle general removal of a stereo system.
    1. Sony CDX-GT540UI Fuse Replacement, Wiring Harness: step 1, image 1 of 1
      • Locate the clip on the wiring harness.
      Ask FixBot
    2. Sony CDX-GT540UI Fuse Replacement: step 2, image 1 of 2 Sony CDX-GT540UI Fuse Replacement: step 2, image 2 of 2
      • Press down on the clip like you would an Ethernet cable.
      • Rock harness side to side, pulling gently towards you until harness detaches.
      Ask FixBot
    1. Sony CDX-GT540UI Fuse Replacement, Fuse: step 3, image 1 of 1
      • Once you have removed the wiring harness.
      • Locate the fuse.
      Ask FixBot
    2. Sony CDX-GT540UI Fuse Replacement: step 4, image 1 of 1
      • Using your index finger and thumb on either side of the fuse.
      Ask FixBot
    3. Sony CDX-GT540UI Fuse Replacement: step 5, image 1 of 1
      • Rock back and forth gently pulling towards yourself until the fuse is removed.
      Ask FixBot
Author
with
Odelkys Marquez
1,139 Reputation
7 Guides authored
USF Tampa, Team 10-2, Brown Fall 2014 Member of USF Tampa, Team 10-2, Brown Fall 2014
USFT-BROWN-F14S10G2
3 Members
84 Guides authored
1 Guide Comment
I would like to sincerely thank the person or persons that took the time ,energy and effort to put forth this information in an easily accessible way. BASICALLY YOU ARE COOL !!
germanspeedster - Reply Share
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 129
All Time: 11,119
