Up to 20% off select tools
Sony CDX-GT540UI Front Panel Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
105
All Time:
3,648
Comments: 4
4 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This will be the initial step for getting into your device for repair.
Before any repair work can be done, one must remove the device from the vehicle. To do so follow this link to see a vehicle general removal of a stereo system.
    1. Sony CDX-GT540UI Front Panel Replacement, Front Panel: step 1, image 1 of 1
      • Locate face-plate eject button.
      Ask FixBot
    2. Sony CDX-GT540UI Front Panel Replacement: step 2, image 1 of 2 Sony CDX-GT540UI Front Panel Replacement: step 2, image 2 of 2
      • Press the eject button.
      • Remove the face-plate.
      Ask FixBot
    3. Sony CDX-GT540UI Front Panel Replacement: step 3, image 1 of 3 Sony CDX-GT540UI Front Panel Replacement: step 3, image 2 of 3 Sony CDX-GT540UI Front Panel Replacement: step 3, image 3 of 3
      • Remove two 4.9mm Phillips #00screws on the front of the device.
      • Remove two 7.5mm Phillips #00screws on the front of the device.
      • When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
      Ask FixBot
    4. Sony CDX-GT540UI Front Panel Replacement: step 4, image 1 of 2 Sony CDX-GT540UI Front Panel Replacement: step 4, image 2 of 2
      • Rotate device 90 degrees to either side.
      • Use the plastic opening tool to pry open the top and bottom tab respectively.
      • Repeat on opposite side.
      Ask FixBot
    5. Sony CDX-GT540UI Front Panel Replacement: step 5, image 1 of 1
      • Remove front panel.
      Ask FixBot
2 other people completed this guide.
Author
with
Odelkys Marquez
1,139 Reputation
7 Guides authored
USF Tampa, Team 10-2, Brown Fall 2014 Member of USF Tampa, Team 10-2, Brown Fall 2014
USFT-BROWN-F14S10G2
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 105
All Time: 3,648
