Sony CDP-CE375 Belt Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
29
Past 30 Days:
146
All Time:
312
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Sony's CDP-CE375 is a great 5-disc CD changer. But over time, its two belts (loading belt for opening the drawer and rotary belt rotating the disc-tray) can stretch, preventing the device from operating properly.
This guide shows how to replace both belts.
NOTE: Most of the screws are brass and are therefore not magnetic. A small grabber tool will be very useful for removing some otherwise hard-to-reach screws.
Also, four of the screws (that attach the chassis to the case) require a screwdriver with a shaft longer than the handles included in the Manta kit. A Philips #1 screwdriver with a shaft that is at least 1.5" long will be necessary.
h/t to these YouTube videos that helped me learn the procedure:
Parts
Tools
    1. Sony CDP-CE375 Belt Replacement, Make sure the device is unplugged: step 1, image 1 of 1
      • When the case is opened, mains-level voltages are accessible. You risk injury from electric shock if performing this procedure while the device is connected to a power outlet.
      Ask FixBot
    2. Sony CDP-CE375 Belt Replacement, Remove cover: step 2, image 1 of 3 Sony CDP-CE375 Belt Replacement, Remove cover: step 2, image 2 of 3 Sony CDP-CE375 Belt Replacement, Remove cover: step 2, image 3 of 3
      • Remove the black screws from the left and right side panels.
      • Remove the two brass screws from the top of the cover.
      • Remove the cover by lifting it straight up. Do not attempt to slide it - it will not move in that direction.
      Ask FixBot
    3. Sony CDP-CE375 Belt Replacement, Disconnect power cables: step 3, image 1 of 2 Sony CDP-CE375 Belt Replacement, Disconnect power cables: step 3, image 2 of 2
      • Disconnect the yellow and white power cables from the front-panel's power switch board. Gently sqeeze each cable's connector's latch and it will easily slide out of its socket.
      Ask FixBot
    4. Sony CDP-CE375 Belt Replacement, Disconnect front panel audio and data cables: step 4, image 1 of 2 Sony CDP-CE375 Belt Replacement, Disconnect front panel audio and data cables: step 4, image 2 of 2
      • Disconnect the front panel ribbon cable from the main board by pulling is straight up.
      • Disconnect the front-panel audio cable by pulling it straight up.
      • During reassembly, be careful when re-inserting the ribbon cable. It is not very fragile, but it can be damaged if it is mis-aligned or if too much force is used during re-insertion.
      Ask FixBot
    5. Sony CDP-CE375 Belt Replacement, Un-route the power cable from the chassis: step 5, image 1 of 2 Sony CDP-CE375 Belt Replacement, Un-route the power cable from the chassis: step 5, image 2 of 2
      • Bend the tie-down clip out of the way to free the power cables.
      • Cut and discard the zip tie attaching the power cables to the chassis. Replacement during reassembly is recommended, but not mandatory.
      • Gently remove the power cord from behind the beige plastic chassis. Remove the black tape that secures it in place. The tape will remain tacky enough to reuse during reassembly.
      Ask FixBot
    6. Sony CDP-CE375 Belt Replacement, Remove the screws securing the front panel: step 6, image 1 of 1
      • Remove the four screws that secure the front panel to the frame. Note that there are two screws inside the right-side foot. Both must be removed.
      • Although these screws appear to be almost identical, they are not. Be careful to not mix them up during reassembly.
      Ask FixBot
    7. Sony CDP-CE375 Belt Replacement, Partially open the CD tray: step 7, image 1 of 2 Sony CDP-CE375 Belt Replacement, Partially open the CD tray: step 7, image 2 of 2
      • Using a small flat-blade screwdriver, turn the white plastic screw located within the indicated hole.
      • There is no need to turn it a lot. One or two turns should be sufficient to unlock the mechanism. You can then gently pull the tray forward a few inches.
      • This is necessary, because the front panel's opening is only wide enough for the CD tray, but its bezel is wider. The panel can be maneuvered around the tray's bezel if the tray is opened partway.
      Ask FixBot
    8. Sony CDP-CE375 Belt Replacement, Remove the front panel: step 8, image 1 of 3 Sony CDP-CE375 Belt Replacement, Remove the front panel: step 8, image 2 of 3 Sony CDP-CE375 Belt Replacement, Remove the front panel: step 8, image 3 of 3
      • Gently un-clip the front panel from the left and right sides of the frame and slide it forward to remove it.
      • The opening in the panel is not wide enough for the tray's front bezel. Pull the left side forward first, and you can maneuver it around the right edge of the bezel.
      • The bezel itself can be disconnected from the tray. Some have found this to be simpler, but it is not necessary.
      Ask FixBot
    9. Sony CDP-CE375 Belt Replacement, Remove rear and bottom chassis screws: step 9, image 1 of 2 Sony CDP-CE375 Belt Replacement, Remove rear and bottom chassis screws: step 9, image 2 of 2
      • Remove the three screws that connect the plastic chassis to the rear panel.
      • Remove the two screws that connect the plastic chassis to the bottom-front edge.
      Ask FixBot
    10. Sony CDP-CE375 Belt Replacement, Disconnect the chassis data cables: step 10, image 1 of 2 Sony CDP-CE375 Belt Replacement, Disconnect the chassis data cables: step 10, image 2 of 2
      • Bend aside the three retaining wires that hold down the data cables.
      • Disconnect the ribbon cable by pulling it straight up
      • Disconnect the second cable, by pulling it straight up.
      • During reassembly, be careful reconnecting these cables. They should not require a lot of force.
      Ask FixBot
    11. Sony CDP-CE375 Belt Replacement, Remove the first two chassis mounting screws.: step 11, image 1 of 3 Sony CDP-CE375 Belt Replacement, Remove the first two chassis mounting screws.: step 11, image 2 of 3 Sony CDP-CE375 Belt Replacement, Remove the first two chassis mounting screws.: step 11, image 3 of 3
      • Move the tray so it is fully open and rotate it to expose the four chassis mounting screws. Remove them.
      • The red box is the upper-left screw location. See also the close-up photo.
      • The orange box is the upper-right screw location. See also the close-up photo.
      • See the next step for close-up locations of the other two screws.
      • These screws are inset a bit. You will need a screwdriver that is at least 1.5" long, preferably 2" or longer. And you will need a grabber tool to remove them, because the screws are brass (non magnetic).
      Ask FixBot
    12. Sony CDP-CE375 Belt Replacement, Remove the remaining two chassis mounting screws.: step 12, image 1 of 2 Sony CDP-CE375 Belt Replacement, Remove the remaining two chassis mounting screws.: step 12, image 2 of 2
      • The yellow box is the location of the lower-left chassis mounting screw.
      • The green box is the location of the lower-right chassis mounting screw. You will need to rotate the tray to make it accessible.
      Ask FixBot
    13. Sony CDP-CE375 Belt Replacement, Remove the chassis from the frame: step 13, image 1 of 1
      • Lift the chassis out of the frame.
      • The loading belt is on the underside of the chassis.
      Ask FixBot
    14. Sony CDP-CE375 Belt Replacement, Notes for chassis reassembly: step 14, image 1 of 3 Sony CDP-CE375 Belt Replacement, Notes for chassis reassembly: step 14, image 2 of 3 Sony CDP-CE375 Belt Replacement, Notes for chassis reassembly: step 14, image 3 of 3
      • During reassembly, do not pinch the power cord under the chassis. It will not fit together properly if you do.
      • Note the location where the power cord enters the device.
      • Note also that there is a notch in the underside of the chassis.
      • The power cord should pass under this notch, to allow the chassis to mount properly onto the metal frame.
      Ask FixBot
    15. Sony CDP-CE375 Belt Replacement, Replace the loading belt: step 15, image 1 of 3 Sony CDP-CE375 Belt Replacement, Replace the loading belt: step 15, image 2 of 3 Sony CDP-CE375 Belt Replacement, Replace the loading belt: step 15, image 3 of 3
      • Flip the chassis upside down.
      • Remove and discard the old loading belt.
      • If the old belt is broken or missing, look for and remove whatever bits you can find.
      • Inspect the two pulleys. If any dirt or belt residue is present, clean them with isopropyl alcohol and a cotton swab. Allow them to fully dry before attaching the replacement belt.
      • Stretch the new belt across the two pulleys.
      Ask FixBot
    16. Sony CDP-CE375 Belt Replacement, Remove the carousel: step 16, image 1 of 2 Sony CDP-CE375 Belt Replacement, Remove the carousel: step 16, image 2 of 2
      • Flip the chassis right-side-up.
      • Using a #0 Phillips or JIS screwdriver, remove the screw at the center of the carousel.
      • Lift the carousel off of the chassis.
      • The gear assembly where the rotary belt may be found is underneath.
      Ask FixBot
    17. Sony CDP-CE375 Belt Replacement, Replace the rotary belt: step 17, image 1 of 2 Sony CDP-CE375 Belt Replacement, Replace the rotary belt: step 17, image 2 of 2
      • Remove and discard the old rotary belt
      Ask FixBot
To reassemble your device, follow these instructions in reverse order (leaving the new belts in-place, of course).
shamino
324 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 146
All Time: 312
