Sony CCD-TR81 Microphone Casing Replacement
    1. Sony CCD-TR81 Microphone Casing Replacement, Disassembling Sony CCD-TR81 Battery: step 1, image 1 of 1
      • Lift viewfinder to access battery pack.
      Ask FixBot
    2. Sony CCD-TR81 Microphone Casing Replacement: step 2, image 1 of 2 Sony CCD-TR81 Microphone Casing Replacement: step 2, image 2 of 2
      • Press the battery release button.
      • While pushing the battery button, slide the battery to the left.
      Ask FixBot
    3. Sony CCD-TR81 Microphone Casing Replacement: step 3, image 1 of 1
      • Pull the battery pack out of the video camera.
      Ask FixBot
    1. Sony CCD-TR81 Microphone Casing Replacement, Outer Case: step 4, image 1 of 3 Sony CCD-TR81 Microphone Casing Replacement, Outer Case: step 4, image 2 of 3 Sony CCD-TR81 Microphone Casing Replacement, Outer Case: step 4, image 3 of 3
      • Open the cassette cover.
      • Unscrew 14 screws located on the outer casing. Three are located on the top face 2x6.8mm and 1X4.54mm, three on the left face 1x4.54mm,1x5.3mm and seven on the bottom face 5x4.54mm and 2x6.77mm.
      Ask FixBot
    2. Sony CCD-TR81 Microphone Casing Replacement: step 5, image 1 of 2 Sony CCD-TR81 Microphone Casing Replacement: step 5, image 2 of 2
      • Remove five screws from the right side, from bottom to top, 3x4.54mm 2x5.70mm.
      • Remove the single 4.5 mm screw from the backside.
      Ask FixBot
    3. Sony CCD-TR81 Microphone Casing Replacement: step 6, image 1 of 1
      • Pull off the plastic tape cover by lifting it up and out of the camera base.
      Ask FixBot
    4. Sony CCD-TR81 Microphone Casing Replacement: step 7, image 1 of 1
      • Disconnect the mic assembly by pulling it away from the camera base.
      • Do not pull too hard as the wires are still connected.
      Ask FixBot
    5. Sony CCD-TR81 Microphone Casing Replacement: step 8, image 1 of 1
      • Pull the bottom part of the case away from the camera.
      Ask FixBot
    6. Sony CCD-TR81 Microphone Casing Replacement: step 9, image 1 of 1
      • Remove the three 4.5 mm screws from the right face of the video camera.
      Ask FixBot
    7. Sony CCD-TR81 Microphone Casing Replacement: step 10, image 1 of 1
      • Remove the single 3.6 mm screw at the front of the video camera on the circuit board.
      Ask FixBot
    8. Sony CCD-TR81 Microphone Casing Replacement: step 11, image 1 of 1
      • Pull the audio/video inputs underneath the microphone assembly. The inputs should still be connected to the circuit board.
      Ask FixBot
    9. Sony CCD-TR81 Microphone Casing Replacement: step 12, image 1 of 1
      • Remove two remaining 3.6 mm case screws from the front of the camera.
      Ask FixBot
    10. Sony CCD-TR81 Microphone Casing Replacement: step 13, image 1 of 2 Sony CCD-TR81 Microphone Casing Replacement: step 13, image 2 of 2
      Tool used on this step:
      Buy
      • Using metal tweezers, pull out the plastic connector box on the front side.
      • Again use metal tweezers to pull out the connection box on the bottom of the camera. The right side of the case can now be removed by pulling it to the right.
      Ask FixBot
    1. Sony CCD-TR81 Microphone Casing Replacement, Microphone Casing: step 14, image 1 of 1
      • Unscrew the blue screw behind microphone and remove it from the video camera 1x3.6mm.
      Ask FixBot
    2. Sony CCD-TR81 Microphone Casing Replacement: step 15, image 1 of 1
      • Pull the circuit board up and away from the microphone case.
      Ask FixBot
    3. Sony CCD-TR81 Microphone Casing Replacement: step 16, image 1 of 1
      • Pull up metal brackets with plastic removal tool.
      Ask FixBot
    4. Sony CCD-TR81 Microphone Casing Replacement: step 17, image 1 of 1
      • With the plastic removal tool, pry up the microphone housing units. This will allow access to the camcorder microphone.
      Ask FixBot
Austin Winther
4 Reputation
1 Guide authored
Cal Poly, Team 11-25, Maness Winter 2011 Member of Cal Poly, Team 11-25, Maness Winter 2011
CPSU-MANESS-W11S11G25
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 1,626
