Sony Bloggie 3D Player USB Drive Replacement
  1. Sony Bloggie 3D Player USB Drive Replacement, Front Cover: step 1, image 1 of 1
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
    Ask FixBot
  2. Sony Bloggie 3D Player USB Drive Replacement: step 2, image 1 of 2 Sony Bloggie 3D Player USB Drive Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
    Ask FixBot
  3. Sony Bloggie 3D Player USB Drive Replacement, Back Cover: step 3, image 1 of 2 Sony Bloggie 3D Player USB Drive Replacement, Back Cover: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
    Ask FixBot
  4. Sony Bloggie 3D Player USB Drive Replacement: step 4, image 1 of 2 Sony Bloggie 3D Player USB Drive Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
    Ask FixBot
  5. Sony Bloggie 3D Player USB Drive Replacement, USB Drive: step 5, image 1 of 2 Sony Bloggie 3D Player USB Drive Replacement, USB Drive: step 5, image 2 of 2
    • Once the back cover is removed, by using the opening tool, remove the following screws using a Phillips #00 screwdriver.
    • Two 4.0mm Phillips #00 screws
    • One 8.0mm Phillips #00 screw
    • One 9.5mm Phillips #00 screw
    Ask FixBot
  6. Sony Bloggie 3D Player USB Drive Replacement: step 6, image 1 of 2 Sony Bloggie 3D Player USB Drive Replacement: step 6, image 2 of 2
    • Using a spudger, remove the clips of the metal casing from each end of the USB drive.
    Ask FixBot
  7. Sony Bloggie 3D Player USB Drive Replacement: step 7, image 1 of 2 Sony Bloggie 3D Player USB Drive Replacement: step 7, image 2 of 2
    • Carefully lift the USB drive off of the peg that it is attached to.
    Ask FixBot
  8. Sony Bloggie 3D Player USB Drive Replacement: step 8, image 1 of 1
    • Now that the USB component is on its own, untangle the ribbon from inside the device.
    Ask FixBot
  9. Sony Bloggie 3D Player USB Drive Replacement: step 9, image 1 of 1
    Buy
    • Now remove the ZIF connector from the device using a pair of tweezers.
    Ask FixBot
Craig Sweet
1 Reputation
1 Guide authored
Cal Poly, Team 7-12, Maness Winter 2013 Member of Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 Members
15 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 25
All Time: 853
