Sony BDP-s7200 Motherboard Replacement
    1. Sony BDP-s7200  Motherboard Replacement, Back Cover: step 1, image 1 of 1
      • Remove the disk tray cover from the device.
      Ask FixBot
    2. Sony BDP-s7200  Motherboard Replacement: step 2, image 1 of 2 Sony BDP-s7200  Motherboard Replacement: step 2, image 2 of 2
      • Using the Phillips #2 Screwdriver, remove the five 9mm from the bottom of the device.
      • Remove the metal cover.
      Ask FixBot
    3. Sony BDP-s7200  Motherboard Replacement: step 3, image 1 of 2 Sony BDP-s7200  Motherboard Replacement: step 3, image 2 of 2
      • Using the Phillips #2 Screwdriver, remove the six 9mm screws from the back of the device.
      Ask FixBot
    4. Sony BDP-s7200  Motherboard Replacement: step 4, image 1 of 1
      • Pull off the back panel and remove it from the device.
      Ask FixBot
    1. Sony BDP-s7200  Motherboard Replacement, Front Panel Cover: step 5, image 1 of 3 Sony BDP-s7200  Motherboard Replacement, Front Panel Cover: step 5, image 2 of 3 Sony BDP-s7200  Motherboard Replacement, Front Panel Cover: step 5, image 3 of 3
      • Using the plastic opening tool, open one of the tabs on the bottom of the device.
      • While keeping the tab open, insert a opening pick in between the opening tool and tab.
      • Repeat this for the 3 other tabs.
      Ask FixBot
    2. Sony BDP-s7200  Motherboard Replacement: step 6, image 1 of 2 Sony BDP-s7200  Motherboard Replacement: step 6, image 2 of 2
      • Place your hands on the two black circles on the bottom of the device.
      • Pull on the black circles to remove the device from its front panel cover.
      Ask FixBot
    3. Sony BDP-s7200  Motherboard Replacement: step 7, image 1 of 3 Sony BDP-s7200  Motherboard Replacement: step 7, image 2 of 3 Sony BDP-s7200  Motherboard Replacement: step 7, image 3 of 3
      • Using the Phillips #2 Screwdriver, remove the seven 9mm screws from the top of the device.
      • Using the same screwdriver, remove the three 9mm screws from the back of the device.
      • Using the same screwdriver, remove the one 9mm screw still connecting the small metal clip to the front of the device.
      Ask FixBot
    4. Sony BDP-s7200  Motherboard Replacement: step 8, image 1 of 2 Sony BDP-s7200  Motherboard Replacement: step 8, image 2 of 2
      • Remove the small metal clip on the front of the device.
      • Remove the metal cover on the top of the device.
      Ask FixBot
    1. Sony BDP-s7200  Motherboard Replacement, Motherboard: step 9, image 1 of 2 Sony BDP-s7200  Motherboard Replacement, Motherboard: step 9, image 2 of 2
      • Remove the ribbon cables connected to the front panel board.
      • Pull firmly, but not too hard as to not damage the ribbon cable.
      Ask FixBot
    2. Sony BDP-s7200  Motherboard Replacement: step 10, image 1 of 1
      • Remove the cable connected to the power supply.
      Ask FixBot
    3. Sony BDP-s7200  Motherboard Replacement: step 11, image 1 of 1
      • Remove the ribbon cables that connect the motherboard to the disk drive.
      • Pull firmly, but not too hard as to not damage the ribbon cables.
      Ask FixBot
    4. Sony BDP-s7200  Motherboard Replacement: step 12, image 1 of 3 Sony BDP-s7200  Motherboard Replacement: step 12, image 2 of 3 Sony BDP-s7200  Motherboard Replacement: step 12, image 3 of 3
      • Remove the three screws using the Phillips #2 Screwdriver.
      • Do not attempt to remove. There is one additional screw on the back of the device.
      • Remove the screw on the back of the device with the same screwdriver.
      Ask FixBot
    5. Sony BDP-s7200  Motherboard Replacement: step 13, image 1 of 2 Sony BDP-s7200  Motherboard Replacement: step 13, image 2 of 2
      • Lift the motherboard from the front and carefully pull it out.
      • There is a small square adhesive on the bottom. Leave it there for reassembly.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 883
