Up to 20% off select tools
Sony BDP-S3700 Wi-Fi Module Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
92
All Time:
1,234
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
The Wi-Fi module connects the Sony BDP-S3700 to Wi-Fi signals and to the internet. This guide shows how to replace it.
    1. Sony BDP-S3700 Wi-Fi Module Replacement, Front Panel: step 1, image 1 of 2 Sony BDP-S3700 Wi-Fi Module Replacement, Front Panel: step 1, image 2 of 2
      • Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
      Ask FixBot
    2. Sony BDP-S3700 Wi-Fi Module Replacement: step 2, image 1 of 2 Sony BDP-S3700 Wi-Fi Module Replacement: step 2, image 2 of 2
      • Remove the back of the device by slowly sliding the rear outer housing backwards.
      Ask FixBot
    3. Sony BDP-S3700 Wi-Fi Module Replacement: step 3, image 1 of 2 Sony BDP-S3700 Wi-Fi Module Replacement: step 3, image 2 of 2
      • Turn the Blu-ray over
      • Pry open the clips under and on the sides
      Ask FixBot
    4. Sony BDP-S3700 Wi-Fi Module Replacement: step 4, image 1 of 1
      • Once all the clips are open, slide the front outer housing out.
      Ask FixBot
    1. Sony BDP-S3700 Wi-Fi Module Replacement, Port Board: step 5, image 1 of 1
      • Flip the Blu-ray back up
      • Remove the ribbon connecting the port board to the motherboard.
      • Handle the circuits only on its side.
      Ask FixBot
    2. Sony BDP-S3700 Wi-Fi Module Replacement: step 6, image 1 of 1
      • Use the PH1 to remove the 7mm screw on the port board.
      Ask FixBot
    3. Sony BDP-S3700 Wi-Fi Module Replacement: step 7, image 1 of 1
      • Remove the port board.
      Ask FixBot
    1. Sony BDP-S3700 Wi-Fi Module Replacement, Wi-Fi Module: step 8, image 1 of 1
      • Remove the ribbon connecting the Wi-Fi module to the motherboard.
      Ask FixBot
    2. Sony BDP-S3700 Wi-Fi Module Replacement: step 9, image 1 of 1
      • Use the PH1 screwdriver to remove the 7mm screw on the module.
      Ask FixBot
    3. Sony BDP-S3700 Wi-Fi Module Replacement: step 10, image 1 of 1
      • Remove the Wi-Fi module
      Ask FixBot
3 other people completed this guide.
Author
with
Luiz Barreto
645 Reputation
5 Guides authored
USF Tampa, Team 12-1, Eyestone Spring 2017 Member of USF Tampa, Team 12-1, Eyestone Spring 2017
USFT-EYESTONE-S17S12G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 92
All Time: 1,234
