Sony BDP-S3700 Motherboard Replacement
  1. Sony BDP-S3700 Motherboard Replacement, Front Panel: step 1, image 1 of 2 Sony BDP-S3700 Motherboard Replacement, Front Panel: step 1, image 2 of 2
    • Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
    Ask FixBot
  2. Sony BDP-S3700 Motherboard Replacement: step 2, image 1 of 2 Sony BDP-S3700 Motherboard Replacement: step 2, image 2 of 2
    • Remove the back of the device by slowly sliding the rear outer housing backwards.
    Ask FixBot
  3. Sony BDP-S3700 Motherboard Replacement: step 3, image 1 of 2 Sony BDP-S3700 Motherboard Replacement: step 3, image 2 of 2
    • Turn the Blu-ray over
    • Pry open the clips under and on the sides
    Ask FixBot
  4. Sony BDP-S3700 Motherboard Replacement: step 4, image 1 of 1
    • Once all the clips are open, slide the front outer housing out.
    Ask FixBot
  5. Sony BDP-S3700 Motherboard Replacement, Disc Drive: step 5, image 1 of 3 Sony BDP-S3700 Motherboard Replacement, Disc Drive: step 5, image 2 of 3 Sony BDP-S3700 Motherboard Replacement, Disc Drive: step 5, image 3 of 3
    • Flip the Blu-ray back up
    • Remove the three ribbon cables that connect the disc drive to the motherboard.
    • Handle the circuits only on its side.
    Ask FixBot
  6. Sony BDP-S3700 Motherboard Replacement: step 6, image 1 of 2 Sony BDP-S3700 Motherboard Replacement: step 6, image 2 of 2
    • Use a PH1 screwdriver to unscrew both of the 7mm screws on the side of the disc reader.
    Ask FixBot
  7. Sony BDP-S3700 Motherboard Replacement: step 7, image 1 of 1
    • Gently slide the disc drive to the right and lift up to remove the disc drive from the body of the player.
    Ask FixBot
  8. Sony BDP-S3700 Motherboard Replacement, Motherboard: step 8, image 1 of 2 Sony BDP-S3700 Motherboard Replacement, Motherboard: step 8, image 2 of 2
    • Gently pull upwards on the ribbon cables to disconnect the motherboard from the Wi-Fi module and port board.
    Ask FixBot
  9. Sony BDP-S3700 Motherboard Replacement: step 9, image 1 of 3 Sony BDP-S3700 Motherboard Replacement: step 9, image 2 of 3 Sony BDP-S3700 Motherboard Replacement: step 9, image 3 of 3
    • Remove the three 7mm screws along the motherboard using a PH1 screwdriver.
    Ask FixBot
  10. Sony BDP-S3700 Motherboard Replacement: step 10, image 1 of 3 Sony BDP-S3700 Motherboard Replacement: step 10, image 2 of 3 Sony BDP-S3700 Motherboard Replacement: step 10, image 3 of 3
    • Remove the 4mm screw above the HDMI port and the 9mm screw Digital Out port.
    Ask FixBot
  11. Sony BDP-S3700 Motherboard Replacement: step 11, image 1 of 1
    • Carefully lift and pull the motherboard forward to remove.
    Ask FixBot
2 other people completed this guide.
Luiz Barreto
645 Reputation
5 Guides authored
USF Tampa, Team 12-1, Eyestone Spring 2017 Member of USF Tampa, Team 12-1, Eyestone Spring 2017
USFT-EYESTONE-S17S12G1
4 Members
5 Guides authored
2 Guide Comments
Thanks for the guide really good! Does anyone know where i can get a sony bdp-s3700 motherboard replacement?
James Durham - Reply Share
Same problem here.
Julian Robbins - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 1,985
