Sony BDP-S3500 Port Board Replacement
  1. Sony BDP-S3500 Port Board Replacement, Front Panel: step 1, image 1 of 2 Sony BDP-S3500 Port Board Replacement, Front Panel: step 1, image 2 of 2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
    Ask FixBot
  2. Sony BDP-S3500 Port Board Replacement: step 2, image 1 of 1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
    Ask FixBot
  3. Sony BDP-S3500 Port Board Replacement: step 3, image 1 of 2 Sony BDP-S3500 Port Board Replacement: step 3, image 2 of 2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
    Ask FixBot
  4. Sony BDP-S3500 Port Board Replacement, Port Board: step 4, image 1 of 2 Sony BDP-S3500 Port Board Replacement, Port Board: step 4, image 2 of 2
    • Keep the back side up and facing towards you.
    • Carefully disconnect the blue ribbon connecting the port board and motherboard.
    • Be delicate while removing the ribbon.
    Ask FixBot
  5. Sony BDP-S3500 Port Board Replacement: step 5, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the 9mm screw from the port board.
    Ask FixBot
  6. Sony BDP-S3500 Port Board Replacement: step 6, image 1 of 1
    • Remove the port board from the device.
    Ask FixBot
Megh Ladumor
100 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 24
All Time: 579
