Sony BDP-S3500 Motherboard Replacement
  1. Sony BDP-S3500 Motherboard Replacement, Front Panel: step 1, image 1 of 2 Sony BDP-S3500 Motherboard Replacement, Front Panel: step 1, image 2 of 2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
    Ask FixBot
  2. Sony BDP-S3500 Motherboard Replacement: step 2, image 1 of 1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
    Ask FixBot
  3. Sony BDP-S3500 Motherboard Replacement: step 3, image 1 of 2 Sony BDP-S3500 Motherboard Replacement: step 3, image 2 of 2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
    Ask FixBot
  4. Sony BDP-S3500 Motherboard Replacement, Disk Drive: step 4, image 1 of 2 Sony BDP-S3500 Motherboard Replacement, Disk Drive: step 4, image 2 of 2
    • Remove the three ribbon cables by gently pulling the cables out of each connector.
    • Be sure to only handle the circuit board from the edges so that the PCB is not damaged.
    Ask FixBot
  5. Sony BDP-S3500 Motherboard Replacement: step 5, image 1 of 2 Sony BDP-S3500 Motherboard Replacement: step 5, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the two 9mm screws that are holding the disk drive in place.
    Ask FixBot
  6. Sony BDP-S3500 Motherboard Replacement: step 6, image 1 of 2 Sony BDP-S3500 Motherboard Replacement: step 6, image 2 of 2
    • Carefully lift and slide the disk drive out of the casing.
    Ask FixBot
  7. Sony BDP-S3500 Motherboard Replacement, Motherboard: step 7, image 1 of 2 Sony BDP-S3500 Motherboard Replacement, Motherboard: step 7, image 2 of 2
    • Remove the ribbon cables by holding onto the cable and gently pulling straight up.
    Ask FixBot
  8. Sony BDP-S3500 Motherboard Replacement: step 8, image 1 of 3 Sony BDP-S3500 Motherboard Replacement: step 8, image 2 of 3 Sony BDP-S3500 Motherboard Replacement: step 8, image 3 of 3
    • Use the Phillips #2 screwdriver to remove three 9mm screws securing the motherboard to the case.
    • Remove one 5.5mm Phillips #2 from the back of the case near the ports.
    Ask FixBot
  9. Sony BDP-S3500 Motherboard Replacement: step 9, image 1 of 1
    • Slide the motherboard away from the back of the case and then lift up to remove.
    Ask FixBot
Michael Meissner
220 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 927
