Up to 20% off select tools
Sony BDP-S1 Fan Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
111
All Time:
3,646
Comments: 5
2 comments on steps, 3 guide comments.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
If you are having issues with overheating it is most likely being caused by a faulty fan. In this guide we will open the player up by removing the connecting screws and then removed the faulty fan so it can be replaced for a new one.
    1. Sony BDP-S1 Fan Replacement, Sony BDP-S1: Getting inside the device: step 1, image 1 of 2 Sony BDP-S1 Fan Replacement, Sony BDP-S1: Getting inside the device: step 1, image 2 of 2
      • Remove the 12mm screws with the Philips #2 screwdriver which keep the plastic panels in place.
      • Don't forget, there are two more 12mm screws on the other side as well.
      Ask FixBot
    2. Sony BDP-S1 Fan Replacement: step 2, image 1 of 3 Sony BDP-S1 Fan Replacement: step 2, image 2 of 3 Sony BDP-S1 Fan Replacement: step 2, image 3 of 3
      • First, remove the three 12mm black screws holding the top panel on (Phillips #2).
      • Then, remove the two 12mm black screws - one on each side of the back of the device - holding the top panel on.
      • Lastly, remove the three 12mm black screws on each side of device.
      Ask FixBot
    3. Sony BDP-S1 Fan Replacement: step 3, image 1 of 3 Sony BDP-S1 Fan Replacement: step 3, image 2 of 3 Sony BDP-S1 Fan Replacement: step 3, image 3 of 3
      • Potential for device damage: Carefully lift up the top panel, because there are two blue ribbon cables that must be disconnected before removing the panel, and we do NOT want them to break.
      • After gently disconnecting the two ribbon cables (you can just pull them out with your hand), take the top off and set it to the side.
      Ask FixBot
    4. Sony BDP-S1 Fan Replacement: step 4, image 1 of 3 Sony BDP-S1 Fan Replacement: step 4, image 2 of 3 Sony BDP-S1 Fan Replacement: step 4, image 3 of 3
      • After the top is off, you'll see that there are two metal bars that go across the top of the device.
      • Remove each bar by unscrewing the two 10mm silver screws on each end.
      Ask FixBot
    1. Sony BDP-S1 Fan Replacement, Fan: step 5, image 1 of 3 Sony BDP-S1 Fan Replacement, Fan: step 5, image 2 of 3 Sony BDP-S1 Fan Replacement, Fan: step 5, image 3 of 3
      • First we need to unscrew the fan from before we can remove it.
      • Remove both copper colored 10mm screws with a #2 phillips screwdriver.
      • As you remove the second screw, pull the fan inward to remove it from the remainder of the case. It should now only be connected to the case through a cable attached to the circuit board.
      • The disk drive is removed in the pictures, however this is not necessary to replace the fan and can be ignored.
      Ask FixBot
    2. Sony BDP-S1 Fan Replacement: step 6, image 1 of 3 Sony BDP-S1 Fan Replacement: step 6, image 2 of 3 Sony BDP-S1 Fan Replacement: step 6, image 3 of 3
      • We will now completely remove the fan from the player.
      • Carefully detach the cable from the fan to the circuit board by pulling on the cable connecting the fan to the circuit board.
      • You are now ready to install the new fan!
      Ask FixBot
Author
with
Nicolas Kennedy
111 Reputation
1 Guide authored
Cal Poly, Team 9-30, Maness Winter 2014 Member of Cal Poly, Team 9-30, Maness Winter 2014
CPSU-MANESS-W14S9G30
3 Members
60 Guides authored
3 Guide Comments
We're can i get a replacement fan for my Blu- ray player model BDV-E4100. HEEEEELP PLEASE.
darren cottenham - Reply Share
@darrencottenham My Sony BDV-E2100 fan has the model number RDM4025S1 written on it. The models BDV-E3100, BDV-E4100, and BDV-E6100 use the same fan model. Maybe you can buy a defect unit to get the fan you are looking for.
Pixel - Reply Share
Where can I get a replacement fan for my blue-ray player.
Christopher Meriweather - Reply Share
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 111
All Time: 3,646
