Sony BDP-BX620 Disk Drive Replacement
    1. Sony BDP-BX620 Disk Drive Replacement, Outer Cover: step 1, image 1 of 2 Sony BDP-BX620 Disk Drive Replacement, Outer Cover: step 1, image 2 of 2
      • Power on the device, eject the disk tray, and power off the device.
      • Turn the device over.
      • Lightly apply downward pressure on the black covering on the disk tray until it comes off.
      • Caution, applying too much pressure can break the black covering.
      Ask FixBot
    2. Sony BDP-BX620 Disk Drive Replacement: step 2, image 1 of 2 Sony BDP-BX620 Disk Drive Replacement: step 2, image 2 of 2
      • Turn the device around.
      • Using a Phillips screw driver, remove the screws on both ends of the device circled red in the image.
      • Slide the side covers on either side towards the back of the device.
      • There is a back cover on either side of the device.
      Ask FixBot
    3. Sony BDP-BX620 Disk Drive Replacement: step 3, image 1 of 3 Sony BDP-BX620 Disk Drive Replacement: step 3, image 2 of 3 Sony BDP-BX620 Disk Drive Replacement: step 3, image 3 of 3
      • This step might require someone to help unclasping the plastic clips.
      • Turn the device so that the bottom is facing up.
      • In the bottom, unclip the three plastic clips circled in red.
      • On either side, unclip the plastic clip circled in red
      • Slide the black covering forwards to remove.
      • All five clips have to be unclasped for the covering to be removed.
      • Careful not to break the plastic clips when putting it back on.
      Ask FixBot
    1. Sony BDP-BX620 Disk Drive Replacement, Disk Drive: step 4, image 1 of 1
      • Remove the no-fuss ribbon cable connectors by gently pulling on them.
      • Pulling harshly may break the flat cables.
      Ask FixBot
    2. Sony BDP-BX620 Disk Drive Replacement: step 5, image 1 of 1
      • Using the Phillips screw driver, remove the three screws.
      Ask FixBot
    3. Sony BDP-BX620 Disk Drive Replacement: step 6, image 1 of 2 Sony BDP-BX620 Disk Drive Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Turn the device over and use tweezers to push the metal clasp until it comes off.
      • Lift the metal brace located over the disk drive and remove the disk drive and the metal brace.
      Ask FixBot
Axel Cruz Jimenez
207 Reputation
3 Guides authored
USF Tampa, Team 1-6, Lacy Fall 2016 Member of USF Tampa, Team 1-6, Lacy Fall 2016
USFT-LACY-F16S1G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 646
