Up to 20% off select tools
Sony BDP-BX620 Bluetooth Module Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
81
All Time:
843
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to remove the Bluetooth module which controls the Bluetooth functions of the device.
    1. Sony BDP-BX620 Bluetooth Module Replacement, Outer Cover: step 1, image 1 of 2 Sony BDP-BX620 Bluetooth Module Replacement, Outer Cover: step 1, image 2 of 2
      • Power on the device, eject the disk tray, and power off the device.
      • Turn the device over.
      • Lightly apply downward pressure on the black covering on the disk tray until it comes off.
      • Caution, applying too much pressure can break the black covering.
      Ask FixBot
    2. Sony BDP-BX620 Bluetooth Module Replacement: step 2, image 1 of 2 Sony BDP-BX620 Bluetooth Module Replacement: step 2, image 2 of 2
      • Turn the device around.
      • Using a Phillips screw driver, remove the screws on both ends of the device circled red in the image.
      • Slide the side covers on either side towards the back of the device.
      • There is a back cover on either side of the device.
      Ask FixBot
    3. Sony BDP-BX620 Bluetooth Module Replacement: step 3, image 1 of 3 Sony BDP-BX620 Bluetooth Module Replacement: step 3, image 2 of 3 Sony BDP-BX620 Bluetooth Module Replacement: step 3, image 3 of 3
      • This step might require someone to help unclasping the plastic clips.
      • Turn the device so that the bottom is facing up.
      • In the bottom, unclip the three plastic clips circled in red.
      • On either side, unclip the plastic clip circled in red
      • Slide the black covering forwards to remove.
      • All five clips have to be unclasped for the covering to be removed.
      • Careful not to break the plastic clips when putting it back on.
      Ask FixBot
    1. Sony BDP-BX620 Bluetooth Module Replacement, Port Board: step 4, image 1 of 2 Sony BDP-BX620 Bluetooth Module Replacement, Port Board: step 4, image 2 of 2
      • Now, spot the large ribbon cable that connects between the motherboard and the port board.
      • Remove the cable by pulling upwards.
      • Be careful when pulling upwards on the ribbon cable. Too much force can cause it to rip.
      Ask FixBot
    2. Sony BDP-BX620 Bluetooth Module Replacement: step 5, image 1 of 1
      • Use your Phillips screwdriver to take out the silver screw holding in the port board.
      Ask FixBot
    3. Sony BDP-BX620 Bluetooth Module Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Now use the tweezers to unclip the portboard on the side.
      Ask FixBot
    1. Sony BDP-BX620 Bluetooth Module Replacement, Bluetooth Module: step 7, image 1 of 2 Sony BDP-BX620 Bluetooth Module Replacement, Bluetooth Module: step 7, image 2 of 2
      • Now, pull the small ribbon cable that connects between the motherboard and the Bluetooth module.
      • Be careful to not pull too hard or the ribbon cable will rip.
      Ask FixBot
    2. Sony BDP-BX620 Bluetooth Module Replacement: step 8, image 1 of 1
      • Use your Phillips screwdriver to remove the silver screw holding the Bluetooth module in place.
      Ask FixBot
    3. Sony BDP-BX620 Bluetooth Module Replacement: step 9, image 1 of 1
      • Lift to remove the bluetooth module from the device.
      • To prevent damage, always hold it on the sides.
      Ask FixBot
Author
with
Zachery Zavala
175 Reputation
2 Guides authored
USF Tampa, Team 1-6, Lacy Fall 2016 Member of USF Tampa, Team 1-6, Lacy Fall 2016
USFT-LACY-F16S1G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 81
All Time: 843
