Sony BDP-BX520 Disc Reader Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
107
All Time:
1,822
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
These step-by-step instruction will allow you to replace the disc reader. This may be necessary if your player will not open or stops playing discs, however, before replacing refer to the troubleshooting page for other tips.
Tools
    1. Sony BDP-BX520 Disc Reader Replacement, Disc Tray Cover: step 1, image 1 of 1
      • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
      • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
      Ask FixBot
    2. Sony BDP-BX520 Disc Reader Replacement: step 2, image 1 of 1
      • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
      Ask FixBot
    3. Sony BDP-BX520 Disc Reader Replacement: step 3, image 1 of 1
      • Close the disc tray, then power off and unplug the Blu-Ray player.
      Ask FixBot
    1. Sony BDP-BX520 Disc Reader Replacement, Top Case: step 4, image 1 of 1
      • Locate the three 8 mm screws on the back of the Blu-Ray player.
      • Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
      Ask FixBot
    2. Sony BDP-BX520 Disc Reader Replacement: step 5, image 1 of 2 Sony BDP-BX520 Disc Reader Replacement: step 5, image 2 of 2
      • Gently pull the top case back to remove it from the Blu-Ray player.
      Ask FixBot
    1. Sony BDP-BX520 Disc Reader Replacement, Front Panel: step 6, image 1 of 1
      • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
      • Lifting these clips may require you to hold one clip open while you move on to the next clip.
      Ask FixBot
    2. Sony BDP-BX520 Disc Reader Replacement: step 7, image 1 of 1
      • Flip device over so the bottom faces you.
      • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
      Ask FixBot
    3. Sony BDP-BX520 Disc Reader Replacement: step 8, image 1 of 1
      • Lift the clip on the opposite side of the device with the nylon or metal spudger.
      Ask FixBot
    4. Sony BDP-BX520 Disc Reader Replacement: step 9, image 1 of 2 Sony BDP-BX520 Disc Reader Replacement: step 9, image 2 of 2
      • Grasp the front case firmly and lift from the rest of the device.
      • Lifting may require some force.
      Ask FixBot
    1. Sony BDP-BX520 Disc Reader Replacement, Disc Reader: step 10, image 1 of 1
      • Do not touch the circuit boards or the internal parts of the device while it is powered on. This could short out the circuits and possibly cause you harm.
      • Plug in the device and power it on by pushing the right button on the front of the device. The light should turn on.
      Ask FixBot
    2. Sony BDP-BX520 Disc Reader Replacement: step 11, image 1 of 1
      • Eject the disc tray by pushing the left button on the front of the device.
      • Unplug the device once the disc tray is open.
      Ask FixBot
    3. Sony BDP-BX520 Disc Reader Replacement: step 12, image 1 of 1
      • Insert the nylon or metal spudger under the clip and lift it up. There are 4 clips that need to be lifted, two on each side
      Ask FixBot
    4. Sony BDP-BX520 Disc Reader Replacement: step 13, image 1 of 2 Sony BDP-BX520 Disc Reader Replacement: step 13, image 2 of 2
      • Once the clips are free, lift the top cover of the disc tray up.
      • This should take minimal force.
      Ask FixBot
    5. Sony BDP-BX520 Disc Reader Replacement: step 14, image 1 of 1
      • Unscrew the two silver 8mm Phillips 1 screws from the disc reader.
      Ask FixBot
    6. Sony BDP-BX520 Disc Reader Replacement: step 15, image 1 of 3 Sony BDP-BX520 Disc Reader Replacement: step 15, image 2 of 3 Sony BDP-BX520 Disc Reader Replacement: step 15, image 3 of 3
      Tool used on this step:
      Buy
      • Use the tweezers to lift both sides of the black clip holding the white 14 pin ribbon in place.
      • Once free the white 24 pin ribbon should slip right out.
      Ask FixBot
    7. Sony BDP-BX520 Disc Reader Replacement: step 16, image 1 of 2 Sony BDP-BX520 Disc Reader Replacement: step 16, image 2 of 2
      • Carefully lift up the disc reader. It is still attached by a cable underneath!
      Ask FixBot
    8. Sony BDP-BX520 Disc Reader Replacement: step 17, image 1 of 2 Sony BDP-BX520 Disc Reader Replacement: step 17, image 2 of 2
      • Gently pull out the white 13 pin cable from the disc reader.
      Ask FixBot
Kyle Smit
243 Reputation
2 Guides authored
Cal Poly, Team 8-41, Amido Winter 2015 Member of Cal Poly, Team 8-41, Amido Winter 2015
CPSU-AMIDO-W15S8G41
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 107
All Time: 1,822
