Sony BDP-BX510 Port Board Replacement
  1. Sony BDP-BX510 Port Board Replacement, Outer Cover: step 1, image 1 of 1
    • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
  2. Sony BDP-BX510 Port Board Replacement: step 2, image 1 of 2 Sony BDP-BX510 Port Board Replacement: step 2, image 2 of 2
    • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
    • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
    • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
    • Do not use too much force to remove the tray cover as you may break it.
  3. Sony BDP-BX510 Port Board Replacement: step 3, image 1 of 2 Sony BDP-BX510 Port Board Replacement: step 3, image 2 of 2
    • Turn to the back of the device.
    • Remove the two 7mm Phillips #2 screws.
    • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
  4. Sony BDP-BX510 Port Board Replacement: step 4, image 1 of 3 Sony BDP-BX510 Port Board Replacement: step 4, image 2 of 3 Sony BDP-BX510 Port Board Replacement: step 4, image 3 of 3
    • Turn the device so you can see the bottom.
    • Unclip the three black plastic clips on the bottom of the device.
    • Unclip one clip on each side of the device.
  5. Sony BDP-BX510 Port Board Replacement: step 5, image 1 of 1
    • Slide the cover forward to remove.
  6. Sony BDP-BX510 Port Board Replacement, Port Board: step 6, image 1 of 1
    • Find the large ribbon cable that connects the port board to the motherboard.
    • Carefully pull directly upwards to disconnect the cable.
  7. Sony BDP-BX510 Port Board Replacement: step 7, image 1 of 1
    • Using the Phillips #1 screwdriver, remove the 5mm screwdriver attached to the port board.
  8. Sony BDP-BX510 Port Board Replacement: step 8, image 1 of 1
    • Unclip the metal piece on the lower right corner by gently lifting it up.
  9. Sony BDP-BX510 Port Board Replacement: step 9, image 1 of 1
    • Remove the port board by simply pulling it away from the device.
Niki Ngosi
375 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 58
All Time: 418
