Sony BDP-BX510 Motherboard Replacement
  1. Sony BDP-BX510 Motherboard Replacement, Outer Cover: step 1, image 1 of 1
    • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
    Ask FixBot
  2. Sony BDP-BX510 Motherboard Replacement: step 2, image 1 of 2 Sony BDP-BX510 Motherboard Replacement: step 2, image 2 of 2
    • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
    • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
    • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
    • Do not use too much force to remove the tray cover as you may break it.
    Ask FixBot
  3. Sony BDP-BX510 Motherboard Replacement: step 3, image 1 of 2 Sony BDP-BX510 Motherboard Replacement: step 3, image 2 of 2
    • Turn to the back of the device.
    • Remove the two 7mm Phillips #2 screws.
    • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
    Ask FixBot
  4. Sony BDP-BX510 Motherboard Replacement: step 4, image 1 of 3 Sony BDP-BX510 Motherboard Replacement: step 4, image 2 of 3 Sony BDP-BX510 Motherboard Replacement: step 4, image 3 of 3
    • Turn the device so you can see the bottom.
    • Unclip the three black plastic clips on the bottom of the device.
    • Unclip one clip on each side of the device.
    Ask FixBot
  5. Sony BDP-BX510 Motherboard Replacement: step 5, image 1 of 1
    • Slide the cover forward to remove.
    Ask FixBot
  6. Sony BDP-BX510 Motherboard Replacement, Motherboard: step 6, image 1 of 1
    • Pull out the power cord from the device.
    Ask FixBot
  7. Sony BDP-BX510 Motherboard Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Pull out these cables from the motherboard.
    • Using tweezers, lift the black tab on the connector of the large 45 pin connector on the motherboard.
    • Pull the large 45 pin ribbon cable out of the connector in the motherboard.
    • Do not use excessive force to remove the cables and do not forcibly pull out the 45 pin ribbon cable as you could damage it. Once the black tab is lifted it should come out easily.
    Ask FixBot
  8. Sony BDP-BX510 Motherboard Replacement: step 8, image 1 of 2 Sony BDP-BX510 Motherboard Replacement: step 8, image 2 of 2
    • Remove the two 5mm Phillips #1 screws.
    • Lift the side of the power module and remove it.
    Ask FixBot
  9. Sony BDP-BX510 Motherboard Replacement: step 9, image 1 of 2 Sony BDP-BX510 Motherboard Replacement: step 9, image 2 of 2
    • Remove the three 5mm Phillips #1 screws.
    • Turn the device over to the backside.
    • Use tweezers or metal spudger to take off the metal clasp for the metal brace near the center on the bottom of the device.
    • Remove the metal brace.
    Ask FixBot
  10. Sony BDP-BX510 Motherboard Replacement: step 10, image 1 of 3 Sony BDP-BX510 Motherboard Replacement: step 10, image 2 of 3 Sony BDP-BX510 Motherboard Replacement: step 10, image 3 of 3
    • Remove the silver 3mm Phillips #1 screw.
    • Remove the black 7mm Phillips #1 screw.
    • Lift the side of the motherboard and pull it out.
    Ask FixBot
Tae (Tim) Im
279 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 525
