Sony BDP-BX510 Disk Tray Replacement
  1. Sony BDP-BX510 Disk Tray Replacement, Outer Cover: step 1, image 1 of 1
    • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
    Ask FixBot
  2. Sony BDP-BX510 Disk Tray Replacement: step 2, image 1 of 2 Sony BDP-BX510 Disk Tray Replacement: step 2, image 2 of 2
    • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
    • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
    • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
    • Do not use too much force to remove the tray cover as you may break it.
    Ask FixBot
  3. Sony BDP-BX510 Disk Tray Replacement: step 3, image 1 of 2 Sony BDP-BX510 Disk Tray Replacement: step 3, image 2 of 2
    • Turn to the back of the device.
    • Remove the two 7mm Phillips #2 screws.
    • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
    Ask FixBot
  4. Sony BDP-BX510 Disk Tray Replacement: step 4, image 1 of 3 Sony BDP-BX510 Disk Tray Replacement: step 4, image 2 of 3 Sony BDP-BX510 Disk Tray Replacement: step 4, image 3 of 3
    • Turn the device so you can see the bottom.
    • Unclip the three black plastic clips on the bottom of the device.
    • Unclip one clip on each side of the device.
    Ask FixBot
  5. Sony BDP-BX510 Disk Tray Replacement: step 5, image 1 of 1
    • Slide the cover forward to remove.
    Ask FixBot
  6. Sony BDP-BX510 Disk Tray Replacement, Disk Tray: step 6, image 1 of 2 Sony BDP-BX510 Disk Tray Replacement, Disk Tray: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Pull the medium-sized 9 pin ribbon cable and the small 5 pin ribbon cable out of their connector in the motherboard.
    • Using tweezers, lift the black tab on the connector of the large 45 pin connector on the motherboard.
    • Pull the large 45 pin ribbon cable out of the connector in the motherboard.
    • Be very careful. The goal is to slightly lift the pin connector, not to completely detach it. Do not forcibly pull.
    Ask FixBot
  7. Sony BDP-BX510 Disk Tray Replacement: step 7, image 1 of 1
    • Remove the 5mm Phillips #2 screw holding the metal brace above the disk tray.
    • Remove the two 5mm Phillips #2 screws that hold the disk tray to the metal case on the bottom.
    Ask FixBot
  8. Sony BDP-BX510 Disk Tray Replacement: step 8, image 1 of 3 Sony BDP-BX510 Disk Tray Replacement: step 8, image 2 of 3 Sony BDP-BX510 Disk Tray Replacement: step 8, image 3 of 3
    • Turn the device over to the backside.
    • Use tweezers or hands to take off the metal clasp for the metal brace near the center on the bottom of the device.
    Ask FixBot
  9. Sony BDP-BX510 Disk Tray Replacement: step 9, image 1 of 1
    • Remove the metal brace then remove the disk tray.
    Ask FixBot
Tae (Tim) Im
279 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 39
All Time: 799
