Sony BDP-BX320 Outer Case Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
48
All Time:
309
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If you need to access the internal components of your Sony BDP-BX320 Blu-ray player, follow this guide to remove the top case.
Tools
    1. Sony BDP-BX320 Outer Case Replacement, Outer Case: step 1, image 1 of 1
      • Power off and unplug the device from any power source.
      • Place the Blue-ray player on a clean, stable surface.
      Ask FixBot
    2. Sony BDP-BX320 Outer Case Replacement: step 2, image 1 of 2 Sony BDP-BX320 Outer Case Replacement: step 2, image 2 of 2
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • If preferred, use the Magnetic Mat to organize screws.
      • Use a Phillips #1 screwdriver to remove the three 8.3 mm screws on the back of the device.
      • Slide the back section of the top case off the device.
      Ask FixBot
    3. Sony BDP-BX320 Outer Case Replacement: step 3, image 1 of 3 Sony BDP-BX320 Outer Case Replacement: step 3, image 2 of 3 Sony BDP-BX320 Outer Case Replacement: step 3, image 3 of 3
      • Use your hands or a metal spudger to gently disconnect the case from the small tabs on the bottom and sides of the device.
      Ask FixBot
    4. Sony BDP-BX320 Outer Case Replacement: step 4, image 1 of 1
      • Slide off the front section of the top case to expose the internal components.
      Ask FixBot
Veronika Saiadian
315 Reputation
2 Guides authored
CSU Los Angeles, Team 5-2, Kershman Fall 2024 Member of CSU Los Angeles, Team 5-2, Kershman Fall 2024
CSULA-KERSHMAN-F24S5G2
6 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 48
All Time: 309
