Sony BDP-BX320 Optical Drive Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
72
All Time:
486
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Introduction
Go to step 1 ↓
This guide will help you replace the optical drive in your Sony BDP-BX320 Blu-ray player. The optical drive is responsible for reading Blu-ray and DVD discs. This guide specifically addresses replacing the optical drive due to errors during playback, audio issues, or distortion.
Unplug the device before starting the repair to avoid electrical hazards. Check the disc tray for dust( you may use as ESD-safe brush or small dust blower). If the player was exposed to liquid or physical damage, inspect for potential issues with other components. Use an anti-static wrist strap to protect internal components from electrostatic discharge (ESD).
Step 7 involves detaching the old optical drive. Have a new optical drive ready for installation, and properly dispose of the old optical drive by following local e-waste disposal guidelines.
Restore the functionality of your Sony BDP-BX320 Blu-ray player with the steps in this guide.
Parts
Tools
    1. Sony BDP-BX320 Optical Drive Replacement, Outer Case: step 1, image 1 of 1
      • Power off and unplug the device from any power source.
      • Place the Blue-ray player on a clean, stable surface.
      Ask FixBot
    2. Sony BDP-BX320 Optical Drive Replacement: step 2, image 1 of 2 Sony BDP-BX320 Optical Drive Replacement: step 2, image 2 of 2
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • If preferred, use the Magnetic Mat to organize screws.
      • Use a Phillips #1 screwdriver to remove the three 8.3 mm screws on the back of the device.
      • Slide the back section of the top case off the device.
      Ask FixBot
    3. Sony BDP-BX320 Optical Drive Replacement: step 3, image 1 of 3 Sony BDP-BX320 Optical Drive Replacement: step 3, image 2 of 3 Sony BDP-BX320 Optical Drive Replacement: step 3, image 3 of 3
      • Use your hands or a metal spudger to gently disconnect the case from the small tabs on the bottom and sides of the device.
      Ask FixBot
    4. Sony BDP-BX320 Optical Drive Replacement: step 4, image 1 of 1
      • Slide off the front section of the top case to expose the internal components.
      Ask FixBot
    1. Sony BDP-BX320 Optical Drive Replacement, Optical Drive: step 5, image 1 of 1
      • Locate the optical drive, which is positioned next to the main board and connected by a wide ZIF connector ribbon cable.
      Ask FixBot
    2. Sony BDP-BX320 Optical Drive Replacement: step 6, image 1 of 3 Sony BDP-BX320 Optical Drive Replacement: step 6, image 2 of 3 Sony BDP-BX320 Optical Drive Replacement: step 6, image 3 of 3
      Phillips #1 Screwdriver
      $5.49
      Buy
      • Use a Phillips #1 Screwdriver to remove the two 7 mm screws that secure the optical drive to the frame of the device.
      • Use a spudger or a clean fingernail to flip up the locking flap of the ZIF connector located between the two "no fuss" ribbon cables that are attached to the board. This action puts the connector in the unlocked position.
      • Use the widest tool possible to avoid damaging the delicate hinge pins.
      • Use tweezers or your fingers to gently pull the cable out of its socket by the blue tab.
      • You may damage the cable by gripping it directly.
      • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
      • Pull the other two "no-fuss" ribbon cables straight out of their socket to disconnect them.
      Ask FixBot
    3. Sony BDP-BX320 Optical Drive Replacement: step 7, image 1 of 1
      • Carefully lift the optical drive out of the device housing.
      Ask FixBot
By following these steps, you should have successfully replaced the optical drive in your Sony BDP-BX320, and resolved playback issues due to a faulty drive. To reassemble, follow these steps in reverse order. Carefully replace the outer casing if needed and screw it back into place. Ensure all screws are tightened, but avoid overtightening.
Veronika Saiadian
315 Reputation
2 Guides authored
CSU Los Angeles, Team 5-2, Kershman Fall 2024 Member of CSU Los Angeles, Team 5-2, Kershman Fall 2024
CSULA-KERSHMAN-F24S5G2
6 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 72
All Time: 486
