Sony BDP-BX320 Motherboard Replacement
  1. Sony BDP-BX320 Motherboard Replacement, Outer Case: step 1, image 1 of 1
    • Power off and unplug the device from any power source.
    • Place the Blue-ray player on a clean, stable surface.
    Ask FixBot
  2. Sony BDP-BX320 Motherboard Replacement: step 2, image 1 of 2 Sony BDP-BX320 Motherboard Replacement: step 2, image 2 of 2
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • If preferred, use the Magnetic Mat to organize screws.
    • Use a Phillips #1 screwdriver to remove the three 8.3 mm screws on the back of the device.
    • Slide the back section of the top case off the device.
    Ask FixBot
  3. Sony BDP-BX320 Motherboard Replacement: step 3, image 1 of 3 Sony BDP-BX320 Motherboard Replacement: step 3, image 2 of 3 Sony BDP-BX320 Motherboard Replacement: step 3, image 3 of 3
    • Use your hands or a metal spudger to gently disconnect the case from the small tabs on the bottom and sides of the device.
    Ask FixBot
  4. Sony BDP-BX320 Motherboard Replacement: step 4, image 1 of 1
    • Slide off the front section of the top case to expose the internal components.
    Ask FixBot
  5. Sony BDP-BX320 Motherboard Replacement, Motherboard: step 5, image 1 of 3 Sony BDP-BX320 Motherboard Replacement, Motherboard: step 5, image 2 of 3 Sony BDP-BX320 Motherboard Replacement, Motherboard: step 5, image 3 of 3
    • Use a spudger or a clean fingernail to flip up the locking flap of the ZIF connector located between the two "no fuss" ribbon cables that are attached to the board. This action puts the connector in the unlocked position.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers or your fingers to gently pull the cable out of its socket by the blue tab.
    • You may damage the cable by gripping it directly.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
    • Use tweezers or your fingers to pull the remaining four "no-fuss" ribbon cables straight out of their socket to disconnect them.
    Ask FixBot
  6. Sony BDP-BX320 Motherboard Replacement: step 6, image 1 of 2 Sony BDP-BX320 Motherboard Replacement: step 6, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the three 7 mm screws that secure the motherboard to the frame of the device.
    • Remove the motherboard from the frame of the device.
    • Be careful when removing the board to disconnect any external ports along the frame's edge that are attached to the motherboard.
    Ask FixBot
By following these steps, you have successfully replaced the motherboard in your Sony BDP-BX320. To reassemble your device, follow these instructions in reverse order. To test, reconnect the device to power and verify functionality. Avoid overtightening screws and handle components with care to prevent damage.
Diego Vergara
165 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 29
All Time: 280
