Sony BDP BX350 Wifi Card Replacement
    1. Sony BDP BX350 Wifi Card Replacement, Control Board: step 1, image 1 of 1
      • Remove the three 10mm Philips head screws on the back of the player.
      Ask FixBot
    2. Sony BDP BX350 Wifi Card Replacement: step 2, image 1 of 1
      • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
      Ask FixBot
    3. Sony BDP BX350 Wifi Card Replacement: step 3, image 1 of 1
      • Lift the tabs located on each side of the device to free the front cover. Begin separating the two covers from metal casing.
      Ask FixBot
    4. Sony BDP BX350 Wifi Card Replacement: step 4, image 1 of 1
      • Remove both covers.
      Ask FixBot
    5. Sony BDP BX350 Wifi Card Replacement: step 5, image 1 of 2 Sony BDP BX350 Wifi Card Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Do not bend or tear the ribbon cable.
      • Using the plastic tweezers, carefully remove the ribbon cable from the motherboard.
      Ask FixBot
    6. Sony BDP BX350 Wifi Card Replacement: step 6, image 1 of 1
      • Unscrew the one 5mm Phillips head screw from the front of the device board.
      Ask FixBot
    7. Sony BDP BX350 Wifi Card Replacement: step 7, image 1 of 2 Sony BDP BX350 Wifi Card Replacement: step 7, image 2 of 2
      • Do not bend or tear ribbon cable.
      • Carefully separate the device control board from the metal casing.
      Ask FixBot
    1. Sony BDP BX350 Wifi Card Replacement, Wifi Card: step 8, image 1 of 2 Sony BDP BX350 Wifi Card Replacement, Wifi Card: step 8, image 2 of 2
      • Remove 6mm Philips head screw from wifi board.
      Ask FixBot
    2. Sony BDP BX350 Wifi Card Replacement: step 9, image 1 of 1
      Buy
      • Remove the ribbon cable from motherboard using a pair of tweezers.
      Ask FixBot
    3. Sony BDP BX350 Wifi Card Replacement: step 10, image 1 of 3 Sony BDP BX350 Wifi Card Replacement: step 10, image 2 of 3 Sony BDP BX350 Wifi Card Replacement: step 10, image 3 of 3
      • Carefully remove board and ribbon cables by pulling upwards then out to free it from the metal clips.
      Ask FixBot
Kristen Vezina
413 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 20
All Time: 558
