Sony BDP BX350 Motherboard Replacement
  1. Sony BDP BX350 Motherboard Replacement, Disc Assembly: step 1, image 1 of 1
    • Remove the three 10mm Philips head screws on the back of the player.
    Ask FixBot
  2. Sony BDP BX350 Motherboard Replacement: step 2, image 1 of 1
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
    Ask FixBot
  3. Sony BDP BX350 Motherboard Replacement: step 3, image 1 of 1
    • Lift the tabs located on each side of the device to free the front cover. Begin to separate the front and metal back covers.
    Ask FixBot
  4. Sony BDP BX350 Motherboard Replacement: step 4, image 1 of 1
    • Completely separate the front cover and the metal back cover from the grey casing.
    • The inner components should all be completely exposed after opening.
    Ask FixBot
  5. Sony BDP BX350 Motherboard Replacement: step 5, image 1 of 1
    • Unscrew the two 8mm Philips head screws securing the disc assembly to the main casing.
    Ask FixBot
  6. Sony BDP BX350 Motherboard Replacement: step 6, image 1 of 1
    • Pull the disc assembly out from under the metal tabs on the main casing.
    Ask FixBot
  7. Sony BDP BX350 Motherboard Replacement: step 7, image 1 of 1
    • Remove disc assembly.
    Ask FixBot
  8. Sony BDP BX350 Motherboard Replacement, Motherboard: step 8, image 1 of 2 Sony BDP BX350 Motherboard Replacement, Motherboard: step 8, image 2 of 2
    • Do not bend or tear the ribbon cable.
    • Remove all five ribbon cables from the motherboard.
    Ask FixBot
  9. Sony BDP BX350 Motherboard Replacement: step 9, image 1 of 1
    • Unscrew 3mm Philips head HDMI screw from metal casing.
    Ask FixBot
  10. Sony BDP BX350 Motherboard Replacement: step 10, image 1 of 1
    • Unscrew the three 5mm Philips head screws from motherboard.
    • Separate the motherboard from the metal casing by pulling directly up. Use an opening tool if necessary.
    Ask FixBot
Kristen Vezina
413 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 882
