Sony BDP BX350 Disc Tray Replacement
    1. Sony BDP BX350 Disc Tray Replacement, Disc Assembly: step 1, image 1 of 1
      • Remove the three 10mm Philips head screws on the back of the player.
      Ask FixBot
    2. Sony BDP BX350 Disc Tray Replacement: step 2, image 1 of 1
      • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
      Ask FixBot
    3. Sony BDP BX350 Disc Tray Replacement: step 3, image 1 of 1
      • Lift the tabs located on each side of the device to free the front cover. Begin to separate the front and metal back covers.
      Ask FixBot
    4. Sony BDP BX350 Disc Tray Replacement: step 4, image 1 of 1
      • Completely separate the front cover and the metal back cover from the grey casing.
      • The inner components should all be completely exposed after opening.
      Ask FixBot
    5. Sony BDP BX350 Disc Tray Replacement: step 5, image 1 of 1
      • Unscrew the two 8mm Philips head screws securing the disc assembly to the main casing.
      Ask FixBot
    6. Sony BDP BX350 Disc Tray Replacement: step 6, image 1 of 1
      • Pull the disc assembly out from under the metal tabs on the main casing.
      Ask FixBot
    7. Sony BDP BX350 Disc Tray Replacement: step 7, image 1 of 1
      • Remove disc assembly.
      Ask FixBot
    1. Sony BDP BX350 Disc Tray Replacement, Disc Tray: step 8, image 1 of 1
      • Take caution to not break plastic tabs.
      • Undo the four tabs on the disc tray assembly.
      Ask FixBot
    2. Sony BDP BX350 Disc Tray Replacement: step 9, image 1 of 2 Sony BDP BX350 Disc Tray Replacement: step 9, image 2 of 2
      • Lift front until back separates.
      Ask FixBot
    3. Sony BDP BX350 Disc Tray Replacement: step 10, image 1 of 1
      • Remove disc from disc tray.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order however do not put the disc back in.
Kristen Vezina
413 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 737
