Sony BDP BX350 Disc Assembly Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
93
All Time:
845
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This is a step-by-step guide on how to open up your Sony BDP BX350 and remove the disc tray assembly. This guide is needed if the disc tray or disc lens are faulty. Make sure the device is unplugged before starting this guide.
Tools
    1. Sony BDP BX350 Disc Assembly Replacement, Disc Assembly: step 1, image 1 of 1
      • Remove the three 10mm Philips head screws on the back of the player.
      Ask FixBot
    2. Sony BDP BX350 Disc Assembly Replacement: step 2, image 1 of 1
      • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
      Ask FixBot
    3. Sony BDP BX350 Disc Assembly Replacement: step 3, image 1 of 1
      • Lift the tabs located on each side of the device to free the front cover. Begin to separate the front and metal back covers.
      Ask FixBot
    4. Sony BDP BX350 Disc Assembly Replacement: step 4, image 1 of 1
      • Completely separate the front cover and the metal back cover from the grey casing.
      • The inner components should all be completely exposed after opening.
      Ask FixBot
    5. Sony BDP BX350 Disc Assembly Replacement: step 5, image 1 of 1
      • Unscrew the two 8mm Philips head screws securing the disc assembly to the main casing.
      Ask FixBot
    6. Sony BDP BX350 Disc Assembly Replacement: step 6, image 1 of 1
      • Pull the disc assembly out from under the metal tabs on the main casing.
      Ask FixBot
    7. Sony BDP BX350 Disc Assembly Replacement: step 7, image 1 of 1
      • Remove disc assembly.
      Ask FixBot
Kristen Vezina
413 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 93
All Time: 845
