Up to 20% off select tools
Sony BDP BX350 Device Control Board Replacement
Views: 1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
87
All Time:
1,043
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This is a step-by-step guide on how to replace your Sony BDP BX350 Device Control Board. This guide is needed if the device control board or USB drive are faulty. Make sure the device is unplugged before starting this guide.
    1. Sony BDP BX350  Device Control Board Replacement, Control Board: step 1, image 1 of 1
      • Remove the three 10mm Philips head screws on the back of the player.
      Ask FixBot
    2. Sony BDP BX350  Device Control Board Replacement: step 2, image 1 of 1
      • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
      Ask FixBot
    3. Sony BDP BX350  Device Control Board Replacement: step 3, image 1 of 1
      • Lift the tabs located on each side of the device to free the front cover. Begin separating the two covers from metal casing.
      Ask FixBot
    4. Sony BDP BX350  Device Control Board Replacement: step 4, image 1 of 1
      • Remove both covers.
      Ask FixBot
    5. Sony BDP BX350  Device Control Board Replacement: step 5, image 1 of 2 Sony BDP BX350  Device Control Board Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Do not bend or tear the ribbon cable.
      • Using the plastic tweezers, carefully remove the ribbon cable from the motherboard.
      Ask FixBot
    6. Sony BDP BX350  Device Control Board Replacement: step 6, image 1 of 1
      • Unscrew the one 5mm Phillips head screw from the front of the device board.
      Ask FixBot
    7. Sony BDP BX350  Device Control Board Replacement: step 7, image 1 of 2 Sony BDP BX350  Device Control Board Replacement: step 7, image 2 of 2
      • Do not bend or tear ribbon cable.
      • Carefully separate the device control board from the metal casing.
      Ask FixBot
Author
with
Cameron Peterson
113 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 87
All Time: 1,043
