Sony Alpha a7s II LCD Replacement
    1. Sony Alpha a7s II LCD Replacement, LCD: step 1, image 1 of 1
      • Orient the camera so that the LCD screen is facing you.
      Ask FixBot
    2. Sony Alpha a7s II LCD Replacement: step 2, image 1 of 1
      • Lift the LCD screen to unscrew the 2 screws on its underside.
      Ask FixBot
    3. Sony Alpha a7s II LCD Replacement: step 3, image 1 of 1
      • Unscrew the 2 screws on the bottom of the LCD screen.
      Ask FixBot
    4. Sony Alpha a7s II LCD Replacement: step 4, image 1 of 1
      • Carefully remove the back of the LCD cover.
      Ask FixBot
    5. Sony Alpha a7s II LCD Replacement: step 5, image 1 of 1
      • Carefully pull up the LCD front cover from the metal internal frame.
      • Be careful of the wire ribbon as it is fragile.
      Ask FixBot
10 other people completed this guide.
4 Guide Comments
And the how do you change the LCD screen please ? How to remove it ?
timothee.ferreol - Reply Share
I have the exact same question, I need to change the screen with flex cable as well. Thanks, there isn’t a lot of info on the a7s 2, it’s all a7r out there
Viro Films - Reply Share
Hello. My LCD backlight stop working after water came into the camera (snow). With a flash light I was able to determine it is the backlight since I was able to detect some menu items on the screen. I bought a replacement LDC unit, my thinking was that the backlight itself was damaged and a new one would do the trick. After replacing the screen, I have the same probleme. So I suppose my problem come from deeper in the camera. The camera itself do not command the backlight to turn on. Is there something I can do? any more troubleshooting?
Thanks!
Jean-Philippe Archibald - Reply Share
What size screws!?
Alain Bucio - Reply Share
Past 24 Hours: 6
Past 7 Days: 28
Past 30 Days: 118
All Time: 14,065
