Sony Alpha NEX-C3 Top Panel Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
96
All Time:
1,451
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The top panel can be cracked, and it's removal is often needed to access other parts under the top panel.
Tools
    1. Sony Alpha NEX-C3 Top Panel Replacement, Top Panel: step 1, image 1 of 1
      • Turn the camera off by sliding the power switch.
      Ask FixBot
    2. Sony Alpha NEX-C3 Top Panel Replacement: step 2, image 1 of 1
      • Use a Phillips head 000 screwdriver to remove the 4.0mm screw inside the USB port.
      Ask FixBot
    3. Sony Alpha NEX-C3 Top Panel Replacement: step 3, image 1 of 1
      • Use a Phillips head 000 screwdriver to remove the one 4.0mm screw on the side opposite of the USB port near the shutter button.
      Ask FixBot
    4. Sony Alpha NEX-C3 Top Panel Replacement: step 4, image 1 of 2 Sony Alpha NEX-C3 Top Panel Replacement: step 4, image 2 of 2
      • Open the flap at the top of the camera.
      • Use a Phillips head 000 screwdriver to remove the two 4.0mm screws inside.
      Ask FixBot
    5. Sony Alpha NEX-C3 Top Panel Replacement: step 5, image 1 of 1
      • Gently lift off the top panel with your hands.
      Ask FixBot
2 other people completed this guide.
Jonathan Chen
720 Reputation
6 Guides authored
1 Guide Comment
Sehr klar und verständlich, ich konnte ohne Probleme folgen.
Stephan Seidel - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 96
All Time: 1,451
