Sony Alpha NEX-C3 LCD Screen Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
114
All Time:
3,816
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
The LCD screen is a helpful display when taking photos. A cracked or damaged screen needs replacement.
Tools
    1. Sony Alpha NEX-C3 LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
      • Turn off the camera by sliding the power switch.
      Ask FixBot
    2. Sony Alpha NEX-C3 LCD Screen Replacement: step 2, image 1 of 1
      • Tilt up the LCD screen.
      Ask FixBot
    3. Sony Alpha NEX-C3 LCD Screen Replacement: step 3, image 1 of 1
      • Use a Phillips head 000 screwdriver to remove the two 2.0mm screws on the bottom of the LCD screen.
      Ask FixBot
    4. Sony Alpha NEX-C3 LCD Screen Replacement: step 4, image 1 of 3 Sony Alpha NEX-C3 LCD Screen Replacement: step 4, image 2 of 3 Sony Alpha NEX-C3 LCD Screen Replacement: step 4, image 3 of 3
      • Use a Phillips head 000 screwdriver to remove the two 1.0mm screws on the smaller backplate of the LCD screen that covers the ribbon cable.
      • The smaller backplate should easily come off. Put it to the side.
      Ask FixBot
    5. Sony Alpha NEX-C3 LCD Screen Replacement: step 5, image 1 of 2 Sony Alpha NEX-C3 LCD Screen Replacement: step 5, image 2 of 2
      • Use a Phillips head 000 screwdriver to remove the two 1.0mm screws on the bigger backplate of the LCD.
      Ask FixBot
    6. Sony Alpha NEX-C3 LCD Screen Replacement: step 6, image 1 of 2 Sony Alpha NEX-C3 LCD Screen Replacement: step 6, image 2 of 2
      • Using the plastic opening tool, remove the larger backplate from the LCD screen.
      Ask FixBot
    7. Sony Alpha NEX-C3 LCD Screen Replacement: step 7, image 1 of 1
      • With your hands, gently remove the black plastic piece on the backside of the LCD screen.
      Ask FixBot
    8. Sony Alpha NEX-C3 LCD Screen Replacement: step 8, image 1 of 3 Sony Alpha NEX-C3 LCD Screen Replacement: step 8, image 2 of 3 Sony Alpha NEX-C3 LCD Screen Replacement: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Using tweezers, gently open the connector. It pivots open. Pull up and away on the ribbon cable connected to the motherboard, after which, the LCD screen should come off.
      • The motherboard ribbon cable has a specific connector.
      Ask FixBot
    9. Sony Alpha NEX-C3 LCD Screen Replacement: step 9, image 1 of 3 Sony Alpha NEX-C3 LCD Screen Replacement: step 9, image 2 of 3 Sony Alpha NEX-C3 LCD Screen Replacement: step 9, image 3 of 3
      • The screen is attached to a frame, via a thin strip of adhesive. Press gently on a corner of the backside of the screen, to detach it from the frame.
      • If your replacement screen did not come with it's own adhesive, carefully peel the original adhesive strip from the original screen, and apply it to the new screen.
      Ask FixBot
    10. Sony Alpha NEX-C3 LCD Screen Replacement: step 10, image 1 of 3 Sony Alpha NEX-C3 LCD Screen Replacement: step 10, image 2 of 3 Sony Alpha NEX-C3 LCD Screen Replacement: step 10, image 3 of 3
      • Insert the new screen in to the frame, ensuring the ribbon cable and copper tab are gently folded inwards within the frame, so they are not damaged.
      • Now you may re-assemble, working backwards from step 8.
      • Enjoy your new screen!
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. However, when installing the ribbon cable, the connector has a specific step. The connector has a tiny flap that clamps down onto the ribbon cable in order to make it secure.
Jonathan Chen
720 Reputation
6 Guides authored
2 Guide Comments
Sir, my unit has many lines that appear on the screen. However, the lcd glass is pristine & has no cracks. Which part is defective? Is the lcd mother board the culprit? Thank you.
Stevie B - Reply Share
Sorry this is probably a little late, but this may mean the ribbon cable for the lcd is damaged, or not properly connected! Follow the screen replacement guide until you have access to the ribbon cable. See if it's damaged or not inserted completely!
Jesse's Heckin' Tech - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 114
All Time: 3,816
