Up to 20% off select tools
Sony Alpha NEX-C3 Control Wheel Replacement
Views: 5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
26
Past 30 Days:
150
All Time:
5,031
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The control wheel is used to navigate through pictures, and can wear down over time, and will need replacement.
    1. Sony Alpha NEX-C3 Control Wheel Replacement, Top Panel: step 1, image 1 of 1
      • Turn the camera off by sliding the power switch.
      Ask FixBot
    2. Sony Alpha NEX-C3 Control Wheel Replacement: step 2, image 1 of 1
      • Use a Phillips head 000 screwdriver to remove the 4.0mm screw inside the USB port.
      Ask FixBot
    3. Sony Alpha NEX-C3 Control Wheel Replacement: step 3, image 1 of 1
      • Use a Phillips head 000 screwdriver to remove the one 4.0mm screw on the side opposite of the USB port near the shutter button.
      Ask FixBot
    4. Sony Alpha NEX-C3 Control Wheel Replacement: step 4, image 1 of 2 Sony Alpha NEX-C3 Control Wheel Replacement: step 4, image 2 of 2
      • Open the flap at the top of the camera.
      • Use a Phillips head 000 screwdriver to remove the two 4.0mm screws inside.
      Ask FixBot
    5. Sony Alpha NEX-C3 Control Wheel Replacement: step 5, image 1 of 1
      • Gently lift off the top panel with your hands.
      Ask FixBot
    1. Sony Alpha NEX-C3 Control Wheel Replacement, Back Panel: step 6, image 1 of 1
      • Use a Phillips head 000 screwdriver to remove the 4.0mm screw at the side opposite of the USB port.
      Ask FixBot
    2. Sony Alpha NEX-C3 Control Wheel Replacement: step 7, image 1 of 2 Sony Alpha NEX-C3 Control Wheel Replacement: step 7, image 2 of 2
      • Use a Phillips head 000 screwdriver to remove the three 4.0mm screws on the bottom of the camera.
      Ask FixBot
    3. Sony Alpha NEX-C3 Control Wheel Replacement: step 8, image 1 of 1
      • Tilt up the LCD screen.
      • Use a Phillips head 000 screwdriver to remove the two coarse 4.0mm screws near the bottom of the camera.
      Ask FixBot
    4. Sony Alpha NEX-C3 Control Wheel Replacement: step 9, image 1 of 1
      • Gently pry off the back panel, by wiggling it around the LCD screen.
      Ask FixBot
    1. Sony Alpha NEX-C3 Control Wheel Replacement, Control Wheel: step 10, image 1 of 2 Sony Alpha NEX-C3 Control Wheel Replacement, Control Wheel: step 10, image 2 of 2
      • Grab the silver plate, and gently pry it up.
      Ask FixBot
    2. Sony Alpha NEX-C3 Control Wheel Replacement: step 11, image 1 of 2 Sony Alpha NEX-C3 Control Wheel Replacement: step 11, image 2 of 2
      • Gently pinch blue ribbon cable, and pull it out of the port.
      Ask FixBot
4 other people completed this guide.
Author
with
Jonathan Chen
720 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 150
All Time: 5,031
