Sony Alpha NEX-6 Lens-release Button Replacement
    1. Sony Alpha NEX-6 Lens-release Button Replacement, Finding the Release Button: step 1, image 1 of 1
      • Turn the camera with the lens facing up.
      • Find the lens release button - located along the side of the silver lens mount.
      Ask FixBot
    2. Sony Alpha NEX-6 Lens-release Button Replacement, Removing the Lens: step 2, image 1 of 2 Sony Alpha NEX-6 Lens-release Button Replacement, Removing the Lens: step 2, image 2 of 2
      • Press and hold the lens release button while rotating the lens counterclockwise.
      • Lift the lens when it is no longer attached to the camera.
      • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
      • Insert the lens and rotate it clockwise until it is locked in place.
      Ask FixBot
    1. Sony Alpha NEX-6 Lens-release Button Replacement, Lens Mount: step 3, image 1 of 1
      • While dealing with this guide, do not touch the delicate image sensor (the center rectangle encircled by the lens mount).
      • After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
      • The outer lens mount ring can now be removed.
      Ask FixBot
    2. Sony Alpha NEX-6 Lens-release Button Replacement: step 4, image 1 of 3 Sony Alpha NEX-6 Lens-release Button Replacement: step 4, image 2 of 3 Sony Alpha NEX-6 Lens-release Button Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Pay attention to the positioning of the spacer rings for reassembly.
      • For the first (black) spacer ring, use the tweezers to gently pry the ring out of place.
      • Repeat this step for the second (silver) spacer ring.
      • The third image is what the camera should look like after all spacer rings are removed.
      Ask FixBot
    3. Sony Alpha NEX-6 Lens-release Button Replacement: step 5, image 1 of 2 Sony Alpha NEX-6 Lens-release Button Replacement: step 5, image 2 of 2
      • To remove the inner lens mount ring, remove the two silver 2.0 mm Phillips #00 screws. This will complete the removal of the lens mount.
      Ask FixBot
    1. Sony Alpha NEX-6 Lens-release Button Replacement, Lens-release Button: step 6, image 1 of 1
      Buy
      • By using tweezers, carefully remove the lens-release button by lifting upward.
      Ask FixBot
Clayton Dale
1,067 Reputation
7 Guides authored
USF Tampa, Team 11-2, Blackwell Winter 2015 Member of USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 30
All Time: 1,960
