Sony Alpha NEX-6 LCD Screen Replacement
    1. Sony Alpha NEX-6 LCD Screen Replacement, Battery: step 1, image 1 of 1
      • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
      • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
      Ask FixBot
    2. Sony Alpha NEX-6 LCD Screen Replacement: step 2, image 1 of 1
      • Flip the camera upside-down and carefully place it on a flat surface.
      • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
      • Push the latch to the right to unlock the battery compartment. The door should flip upward.
      Ask FixBot
    3. Sony Alpha NEX-6 LCD Screen Replacement: step 3, image 1 of 1
      • With the compartment open, locate a blue tab shown with spudger
      • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
      Ask FixBot
    1. Sony Alpha NEX-6 LCD Screen Replacement, Removing back screws: step 4, image 1 of 1
      • Remove the two 1.0 mm Phillips #00 screws from back of the LCD screen.
      Ask FixBot
    2. Sony Alpha NEX-6 LCD Screen Replacement, Removing bottom screws: step 5, image 1 of 1
      • Remove the two 1.5 mm Phillips #00 screws from the bottom of the screen mount assembly.
      Ask FixBot
    3. Sony Alpha NEX-6 LCD Screen Replacement, Back cover: step 6, image 1 of 2 Sony Alpha NEX-6 LCD Screen Replacement, Back cover: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Using a plastic opening tool pry off the back cover from the screen assembly.
      • Remove back cover by lifting it away from the screen using tweezers.
      Ask FixBot
    4. Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: step 7, image 1 of 3 Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: step 7, image 2 of 3 Sony Alpha NEX-6 LCD Screen Replacement, Ribbon cable: step 7, image 3 of 3
      • Release the ribbon cable by lifting the black locking latch with the plastic opening tool.
      • Pry out the ribbon cable by carefully sliding it out of the connection slot using a spudger.
      Ask FixBot
    5. Sony Alpha NEX-6 LCD Screen Replacement, Upper plastic separator: step 8, image 1 of 1
      • Lift and slide out the upper black plastic separator using tweezers.
      Ask FixBot
    6. Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: step 9, image 1 of 3 Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: step 9, image 2 of 3 Sony Alpha NEX-6 LCD Screen Replacement, Lower plastic separator: step 9, image 3 of 3
      • Lift and remove the lower black plastic separator using tweezers.
      • Using the pointy side of a spudger push in the screen lock button release it.
      • The screen lock button can now be removed.
      Ask FixBot
    7. Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: step 10, image 1 of 3 Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: step 10, image 2 of 3 Sony Alpha NEX-6 LCD Screen Replacement, Black nylon sheet: step 10, image 3 of 3
      • Using the flat end of the spudger, push on the black nylon sheet glued to the metallic frame to peel it of.
      • Apply force from different spots to avoid tearing the sheet.
      • Remove the black nylon sheet using tweezers.
      Ask FixBot
    8. Sony Alpha NEX-6 LCD Screen Replacement, Screen Removal: step 11, image 1 of 1
      • Gently wiggle the screen loose and remove it from the mount.
      Ask FixBot
6 other people completed this guide.
Clayton Dale
1,067 Reputation
7 Guides authored
USF Tampa, Team 11-2, Blackwell Winter 2015 Member of USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Members
84 Guides authored
2 Guide Comments
Thanks a million! Great guide and saved me $250 sending it back in.
Al Weiner - Reply Share
Hi - I am trying to fix one of these -- and the guy I bought it from pulled off and lost the black locking latch from the ribbon cable rather than just lifting it -- I can get the LCD screen to light but can't keep it on very long -- I bought another one of these internal cables with the black locking latch. Do you think I can pop that one off and move it to this one? Or do you have any source of instructions how to replace that cable?
Cheers and thanks for this!
PS -- If anyone is just trying to get rid of the dreaded bubbles in the screen saver that plagues these NEX cameras -- it does just peal off -- see youtubes,,,
Harvey Cat - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 60
All Time: 8,280
