Sony Alpha NEX-6 Battery Replacement
    1. Sony Alpha NEX-6 Battery Replacement, Battery: step 1, image 1 of 1
      • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
      • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
      Ask FixBot
    2. Sony Alpha NEX-6 Battery Replacement: step 2, image 1 of 1
      • Flip the camera upside-down and carefully place it on a flat surface.
      • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
      • Push the latch to the right to unlock the battery compartment. The door should flip upward.
      Ask FixBot
    3. Sony Alpha NEX-6 Battery Replacement: step 3, image 1 of 1
      • With the compartment open, locate a blue tab shown with spudger
      • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
      Ask FixBot
2 other people completed this guide.
Clayton Dale
1,067 Reputation
7 Guides authored
USF Tampa, Team 11-2, Blackwell Winter 2015 Member of USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Members
84 Guides authored
3 Guide Comments
Battery Stuck
rustychinnis - Reply Share
Will not spring out. Any ideas?
Got it, battery damaged. Tapped on edge to remove battery
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 29
All Time: 3,080
