Up to 20% off select tools
Sony Alpha NEX-6 Back Case Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
30
Past 30 Days:
131
All Time:
5,146
Comments: 3
3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide includes screws removal and a procedure for removing the back case. Follow the steps precisely to avoid breaking of plastic locking tabs.
    1. Sony Alpha NEX-6 Back Case Replacement, Battery: step 1, image 1 of 1
      • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
      • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
      Ask FixBot
    2. Sony Alpha NEX-6 Back Case Replacement: step 2, image 1 of 1
      • Flip the camera upside-down and carefully place it on a flat surface.
      • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
      • Push the latch to the right to unlock the battery compartment. The door should flip upward.
      Ask FixBot
    3. Sony Alpha NEX-6 Back Case Replacement: step 3, image 1 of 1
      • With the compartment open, locate a blue tab shown with spudger
      • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
      Ask FixBot
    1. Sony Alpha NEX-6 Back Case Replacement, Battery compartment screws: step 4, image 1 of 1
      • Remove the two 3.5mm Phillips #00 screws that hold the back case - located inside the battery compartment.
      Ask FixBot
    2. Sony Alpha NEX-6 Back Case Replacement, Bottom screws: step 5, image 1 of 1
      • Remove the two 3.5mm Phillips #00 screws that hold the back case - located on the bottom of the camera.
      Ask FixBot
    3. Sony Alpha NEX-6 Back Case Replacement, Side screws: step 6, image 1 of 1
      • Remove the 3.5 mm Phillips #00 screw on the side of camera - located between the charging and HDMI ports.
      • Remove the 4.0 mm Phillips #00 screw on the side of the camera - located next to the WiFi sign.
      Ask FixBot
    4. Sony Alpha NEX-6 Back Case Replacement, Dis-attaching procedure: step 7, image 1 of 2 Sony Alpha NEX-6 Back Case Replacement, Dis-attaching procedure: step 7, image 2 of 2
      • Starting with the battery compartment gently begin to separate the back case front the camera.
      • Using a plastic opening tool, separate the bottom of the back case from the camera. Then proceed by separating the sides.
      • Gently lift the back case away from the camera an slide it down to completely remove the back case.
      Ask FixBot
2 other people completed this guide.
Author
with
Clayton Dale
1,067 Reputation
7 Guides authored
USF Tampa, Team 11-2, Blackwell Winter 2015 Member of USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Members
84 Guides authored
3 Guide Comments
At {STEP 7} you will notice the last parts to release are the flash button / record button areas. This is particularly tricky.
The flash button release seems to be attached inside, so take care. In my case I did not remove the back case completely due to this.
The corner where the record button is requires extra force to slide down / pry out.
Re-assembly : Take note of these parts.
- the PLAY button flexible circuit has a small hole which fits into a pin on the back case. It is important to align this correctly or your play & AEL button may not function.
- The eye piece has a flexible circuit on its right side which tucks behind a small tab - take care this is not dislodged or it could be damaged when re assembling.
Riquez JP - Reply Share
Does your team know how to fix the Flash Pop-up button ? It seems the flash for me and others is stuck open and can't be clicked back down. Can you assist ?
rullor - Reply Share
Can you please let me know how to replace the battery door? Thank you.
Richard Bullough - Reply Share
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 131
All Time: 5,146
