Sony Alpha NEX-5N E-mount Replacement
    1. Sony Alpha NEX-5N E-mount Replacement, E-mount: step 1, image 1 of 2 Sony Alpha NEX-5N E-mount Replacement, E-mount: step 1, image 2 of 2
      • While completing this guide, do not touch the image sensor (the center rectangle encircled by the lens mount).
      • Unscrew the 4 silver 1.2 mm Phillips #000 screws along the front outer lens mount.
      • Applying extra force to unscrew these 4 screws may be necessary.
      • Detach the outer lens mount ring.
      Ask FixBot
    2. Sony Alpha NEX-5N E-mount Replacement: step 2, image 1 of 2 Sony Alpha NEX-5N E-mount Replacement: step 2, image 2 of 2
      • Pay attention to the positioning and order of the spacing rings for reassembly.
      • Using your fingers, pull out the first black spacer ring.
      • Repeat the previous step for the second silver spacer ring.
      Ask FixBot
    3. Sony Alpha NEX-5N E-mount Replacement: step 3, image 1 of 3 Sony Alpha NEX-5N E-mount Replacement: step 3, image 2 of 3 Sony Alpha NEX-5N E-mount Replacement: step 3, image 3 of 3
      • Unscrew the 2 silver 1.2 mm Phillips #000 screws on opposing sides in the lens ring area.
      • Using your fingers, easily pull off lens housing. This will complete the removal of the E-mount.
      • The lens release button and the small spring underneath will be loose.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 32
All Time: 1,975
